Hi all i was wondering if ne1 had a circuit that would turn on my router when my operation starts and stop it when the operation is over. it's a 110v router. thanks Tom |
| Ok, on a solid state relay you have 4 tabs, 1-2 are for switching the live (black) from your router, the tab3-4 are to control the relay from 3-32v.(*Note solid-state relays are polarised, you have tab 3 (+) and tab 4 (-) ). You wire the gnd from your parallel port to the tab 4 (-) and the signal wire to the tab 3 (+).I'm using pin 16 to control my router depending of your software setup. I'f you have another question, let me know. Thanks, Alex www.aghobby.com |
| I just got my solid state relay today, I have not hooked it up yet though. The solid state relay can be turned on or off by the voltage provided by your parallel port. Some boards like the xylotex have a separate plug that just connects directly to the parallel port. When your toolpath software is configured correctly, it can send a signal through the parallel port and into your relay, turning it on or off. You hook the other side up to your spindle and away you go. co |
| I use the Mitsubishi SF16DAZ-H1-4, but you can also use the Crydom D1210. I prefer the Mitsubishi, smaller and a 16A capacity. You can find it for free in old ...i don't know the english word but in french is a "photocopieur". Here the picture of both.
__________________ Alex www.ebfcnc.com |
| Finding The Right Router | Crushmonkey | Commercial CNC Wood Routers | 22 | 06-19-2006 02:17 AM |
| I'm looking for a mini router / circuit engraver | NickLatech | DIY-CNC Router Table Machines | 0 | 01-14-2005 01:26 AM |
| Noise in Bridgeport 2J head (audio file included) | daytrader | Bridgeport and Hardinge Mills | 4 | 11-15-2004 08:31 PM |
| adapting a router to mini? | JFettig | Benchtop Machines | 0 | 04-30-2004 07:51 PM |
| 5 Axis Rotery Head Home Cnc Router | mace | DIY-CNC Router Table Machines | 22 | 09-18-2003 12:29 PM |
