Old 03-26-2007, 01:52 PM
nydheart is on a distinguished road
Did I buy the wrong motors?
Hi guys, I received me motors, controller and power supply today that I will be using for my Rockcliff router but I think I may have not done my homework properly. The unit I got was a used steppeworld SP3 controller with power supply, resistors and 3 stepper motors. Looking at the motors however I think they may be to small for what I want to do. They are Japan Servo with these specs: Unipolar / 2 phases 6 Volts DC (nom) 1.2 Amps / Phase (nom) 2.4 Amps / Motor 1.8 Degree/Step 80 oz/Inch 6 wires. I wan't to use the Rockcliff to router 6x10 wood signs. Are these motors undersized for the job? I think I should have gone with 190 oz in? Thanks for any advice.
Nyd,
Old 03-26-2007, 03:10 PM
awerby is on a distinguished road
Is that 6 x 10 inches or feet?
If it's the former, then the 80 oz-in motors might work, assuming you keep the gantry light and use ball-screws to minimize friction. If you're really proposing to run a large router with these tiny motors, then you'll have to gear them down so far that you'll hardly notice when it's moving. For a big router, look into big steppers (34 frame) or better yet, servo motors.
Old 03-26-2007, 03:15 PM
Hi sorry about that, it is in fact 6x10 inches. Thanks.
Old 03-26-2007, 05:27 PM
Jason Marsha is on a distinguished road
If you are using 1/4 - 20 all thread rod these motors should work. Personally I would have purchased the hobbycnc kit with at least the 127 oz/inch motors.
Jason
Old 03-26-2007, 06:01 PM
I am using 1/4 - 20 rod as per the design specs. Am I going to be limited to what I can do using these motors or does the finishing router have something to do with how the machine operates? I am thinking of using a dewilt or a rotozip with the variable speed settings. Would that be ok for this machine or should I be looking at a different type of router? Thanks for helping a super newbie.
Nyd.
Old 03-26-2007, 06:34 PM
Netjams is on a distinguished road
Those motors should work just fine, but I would not use a rotozip they can't hold up to the long running times because of the plastic fan they use in it.
Old 03-26-2007, 08:09 PM
What would you recommend I use? Would a similar dewilt type of finishing tool work? Thanks.
Nyd.
Old 03-26-2007, 08:42 PM
Nyd.
I not sure of the construction of Dewalt trim router but from what I have read about them they are far better then a Rotozip.
Old 03-26-2007, 11:04 PM
tpworks's Avatar
tpworks is on a distinguished road
I hve been using a dewalt laminte trimmr for about 4 years on my 24" x 36" table and it has held up great with no problems so far. I make wooden signs. cutting 1/8" to 3/16" deep with the occasional cutout.
What am I doing WRONG??? elalto Mach Software (ArtSoft software) 2 07-21-2006 05:23 AM
When everything goes wrong. ImanCarrot General Metalwork Discussion 4 04-23-2006 09:42 PM
anyone know what i am doing wrong pauluk Digitizing and Laser Digitizing 14 02-16-2006 10:48 AM
What is wrong with these motors? musicmkr Stepper Motors and Drives 1 05-04-2005 10:57 AM
I & J vs R, what went wrong little bubba Fadal 9 05-02-2005 06:23 PM
