Hi, I am a NEWBIE here and I have a few questions.Someone I know said that if I wanted to use my cnc router to make guitars with it I would need a special program for this,so if yes which one and do I have to program every little detail like how deep to rout or stuff like that.How do I setup all the 0 points xyz and so on ,as you can see I am as about newb as it get and thanks for any help. |
| You would need 3D cad skills and some CAM (computer aided machining) skills too to make a guitar body from a block that only requires sanding and finishing. If you dont mind doing some work manually, you only need 2D cad skills to cut out the body's basic shape. E
__________________ I wish it wouldn't crash. |
| If you already have a CNC router and know how to use it, I see no special programs necessary to build a guitar. Simple 2D toolpaths should be all that are necessary. What CAD and CAM packages do you currently use? What type(s) of guitars are you wanting to build?
__________________ My name is Electric Nachos. Sorry to impose, but I am the ocean. http://www.bryanpryor.com (Note: The opinions expressed in this post are my own and are not necessarily those of CNCzone and its management) |
| Hi guys, thanks for the replies,I have some basic cad skills but no cam skills. I have several proggies (autocad,bobcad,3dmax6,solidworks) and i dont mind doing some extra work.I am looking at builing a custom jem(Steve Vai) to my specs because thwere isnt one out there that suits my personal taste and I also want it for inlay work. |
| If you can model the body in MAX, you can export it as a .dxf and use MeshCAM ( http://www.robgrz.com ) to create the toolpaths for the machine to carve the body. Meshcam is free right now while in beta, but it works pretty good. Download it and play with it. Gerry
| Newbie - To build or not to build Router/Plasma Table | dfranks | CNC Plasma and Waterjet Machines | 10 | 04-08-2011 12:16 AM |
| Complete Newbie seeking for help. - Clisby mini machines. | some8 | Mini Lathe | 11 | 03-13-2006 09:23 AM |
| Chopper for AVR from complete newbie, comments pls | genericuser | Open Source Controller Boards | 12 | 03-31-2005 10:22 PM |
| Autocad user has newbie SW/CNC questions | cadesignr | Solidworks | 7 | 02-11-2005 02:19 PM |
| Newbie says HOWDIE! | cadesignr | Autodesk Software (Autocad, Inventor etc) | 1 | 03-21-2004 12:19 PM |
