Old 03-24-2007, 11:03 PM
bearracecars is on a distinguished road
recomendations for aluminum cutting bits
hi all
posted this in a different location but will try here also. what bits work best for routing aluminum sheet? anyone have experience with this? what works and what doesn't?
thanks alot
bear
Old 03-25-2007, 01:50 AM
pk7639 is on a distinguished road
We had a bit of a play with speeds and feeds using a few cutters, Results here:
http://www.cncathome.com/speedsnfeeds.html
Hope it helps.
PK
Old 03-25-2007, 10:55 AM
shovelitdeep is on a distinguished road
you can get reverse spiral end mills that work well if there is a similarly profiled support under the sheet. they work by pushing the sheet down, instead of lifting it, MSC has them, I think. Where I used to work we got them through msc, but we used a lot of them so it may have been worth it fr the sales guy to track them down
they will not drill down though. there are also end mills that have both spirals that work because the spirals counteract each other
Old 03-25-2007, 11:18 AM
ger21's Avatar
www.onsrud.com has an entire catalog of router bits for aluminum. www.onsrud.com
Old 03-25-2007, 11:50 AM
S*mmy is on a distinguished road
Msc
Just a note on MSC, Delivery is great, inventory is there........prices are sometimes higher than other tooling suppliers. I've compared at sometimes 40% higher through MSC......
Old 03-25-2007, 01:17 PM
spoiledbrat is on a distinguished road
msc?
I agree that MSC is an awesome supplier (with their 5000 page catalog)
Look for their sales. I receive a magazine (small, on sale stuff catalog), and they always have end mills in there. For instance, I purchase a couple of 1/2", 2 flute, solid carbide end mills for only 50 dollars. That is about the same as a low-tech router bit at Lowes.
Old 03-25-2007, 03:42 PM
Jimildoo is on a distinguished road
Aluminum cutting
The grade of aluminum is an important factor. Grades good for anodising are soft and not good for router cutting - it is like stirring porridge. Harder marine and machining grades give completely different results. A cold-air gun and a little vegetable oil based liquid lubricant assists by preventing the tool from heating up causing the material to stick to it. Single flute tools perform well because of superior chip removal. Experiment with climb/conventional cutting as well as speed - the back side of the cut can be a mess but the front side shiny and clean.
Old 03-25-2007, 04:12 PM
thanks for all the replies. i've been searching all over and have found aluminum cutters but a little confussed on which works best. onsrud spiral o's, two flute, single flute, high speed steel, carbide. so many choices not enough money. Cooling seems to be really important. even read about alcohol based misting fluids, anybody use that?
thanks
bear
Old 03-25-2007, 04:14 PM
msc is great. order from them weekly along with mc-master. i just wish mc-master wasn't so hard to get a catalog from.
bear
Old 03-26-2007, 12:20 AM
edmond is on a distinguished road
Smile
I use Belin Yvon Spiral O upcut aluminium cutters along with a coolant mixture of paraffin and aluminium cutting fluid.The Belin Yvon cutter are from France and they are really top quality, made from micro grain carbide.I order them from my local Multicam dealer here in South Africa.
  #11   Ban this user!
Old 03-26-2007, 12:48 AM
maxman is on a distinguished road
Lightbulb Cuttin Aluminuim - Easy
Hi . I have 2 Multicam Routers and all we do is cut alu, all day every day. We have tried almost all the bits out there and have settled on this combo. Onsrud single flute for softer grades and WPW two flute Solid cabide Bits for every thing else. ,
!But here is the impotant part!
We mix a solution of cutting oil and parrafin ( 10% Castrol Sulfex D and 90 % Illuminating Parrafin) and then spray it on the tool with a dual spray misting system.
The softer the Alu - The More Mist you apply.
Also - we are cutting at 20 millimeters per second with a spindle speed of 11000 rpm , cutter diameter between 6 and 10 , and usually only cutting half the bits diameter in depth.
Hope this helps
  #12   Ban this user!
Old 03-26-2007, 04:03 AM
frenzal is on a distinguished road
We cut a lot of ally mainly between 3 and 20mm thick on a home made router. We use solid carbide, single flute cutters between 3mm and 10mm diameter. Most of them we run at 1000mm/min with a 1mm depth of cut. The 10mm we can push up to 1500mm/min and the 3mm we run a bit slower. We get a good finish on the part if we use climb mill.
We don't use any cutting lubricants (mainly because we use the router for wood too and don't want to get it all greasy). Spindle speed is 20,000rpm for most of the bits and 25,000 for the 3mm ones (approx).
Good luck with it!
Recomendations on aluminum cutting bits bearracecars Commercial CNC Wood Routers 0 03-22-2007 02:49 PM
End mill bits and aluminum. Questions. SCCoupe Benchtop Machines 5 06-28-2006 11:11 AM
wood spade bits on aluminum??? lurch General Metalwork Discussion 4 01-16-2006 12:21 AM
Stronger cutting bits studysession General Metalwork Discussion 15 12-07-2004 01:36 AM
Can I use Forstner bits on aluminum? samualt DIY-CNC Router Table Machines 14 10-24-2004 12:35 PM
