Does anyone have any ideas or suggestions on how I can turn down the ends of acme rod so it will fit the inner diameter of roller blade bearings. I don't have a lathe and would like to know if there are any diy methods that will produce good enough results. I like the setup that eric (balsaman) used on his cnc router lead screws. |
| I had mine turned by a machine shop, but since yours are already turned you might want to consider just getting the appropriate bearings. I bought some from Ebay. There is a guy there that sells almost every size you could want for a very reasonable price. T |
| Chuck it into a drill, hold end with UHMW or wood, spin drill with foot while holding a file to the screw. Takes a long time, but is free! If I get some time this weekend, I'll draw up plans for an idea I've had for just this purpose. Sort of a poor mans lathe. If I'm lucky, I may get the time to build one!
__________________ Stop talking about it and do it already!!!!! (Note: The opinions expressed in this post are my own and are not necessarily those of CNCzone and its management) |
| It works...really! Never got the time to try the other idea though. Don't even remember it now!
| Get some bearings that slide onto the rod. Make a fixture out of mdf that will hold the bearings and the leadscrew horizontally so it will spin in the bearings. Use a drill motor to turn the rod. Then attach the fixture to your CNC machine. Use a grinding wheel in a grinder to turn the ends down in light passes. Hopefully you aren't tearing your machine apart and can still use it. Chris |
| Park your car next to a curb. Jack up either the front or rear, depending on whether its FWD or RWD. Weld end of acme rod to approximate center of wheel. Start engine and put in gear to start wheel and rod spinning. Slowly lower jack until rod grinds against curb. Use foot (with stout shoe attached) to step on rod and feed it into the curb. When finished, drive car to supplier and buy more rods. Drop them off on the way home to a machine shop who can turn them to size and maintain concentric diameters so they don't flop around like an epileptic bullwhip when you install them on your machine. |
#10
| LMAO!! Kurt (The Swede) has a write up of the right way to do this here: http://www.5bears.com/cnc16.htm Still need a lathe though.
__________________ Regards, Mark www.wrathall.com |
| Thread milling, can anyone help | jtrav | General CAM Discussion | 16 | 03-06-2006 02:25 PM |
| 304 stainless steel slide rods | bertvk | DIY-CNC Router Table Machines | 8 | 09-25-2004 04:35 PM |
| what acme tap do I need for the Enco ACME rod? | AJ_Mac2001 | DIY-CNC Router Table Machines | 15 | 03-08-2004 07:24 AM |
| Manual thread turning handle | JFettig | General Metal Working Machines | 4 | 03-05-2004 06:46 AM |
| Thread milling cutterdia / hole ratio | HuFlungDung | Machine Problems, Solutions , Wireless DNC, serial port | 3 | 12-31-2003 08:44 PM |
