Old 03-16-2007, 07:23 PM
temler is on a distinguished road
Talking need help make the choice on what plan to use
Hi
I think I have it down to David Steel's plans or the jgro plans and Joes plans. Can any one give the pro and cons of each of these. I want to do carving in oak, cherry, and maple. I have to be able to cut min 20" wide and 36 to 43 long.
Thanks for all your help. The more info the better.
Tim Emler
Old 03-16-2007, 07:41 PM
edo edo is offline
edo is on a distinguished road
I can only comment on the JGRO. It was easy to build from the plans, but you would have to make modifications to get the size you need. The effective cutting area on mine is only 15 1/4" x 27 1/4". Extending the gantry 5" may introduce too much flex, especially if you're doing 3D carving.
Old 03-18-2007, 09:19 AM
alwaysready is on a distinguished road
joes plans are 2' x 4' cutting area as i remeber, designed to be used a that size but of course with size and strength comes cost and accuracy(no flexing, compared to stretching out the jgro plans)
Old 03-18-2007, 09:24 AM
ger21's Avatar
For the size you want, Joes would probably be the best bet. Not too familiar with the Solsylva, but from what I've read, the leadscrew models are quite slow as well.
If you had the choice, which SS would you choose? PEU General Metalwork Discussion 25 10-06-2006 07:19 AM
stepper motor -b.o.b choice jarr88 Gecko Drives 0 09-28-2006 06:43 PM
VFD choice zcases Phase Converters and VFD 0 09-30-2005 08:59 AM
Stepper choice JW Peters Stepper Motors and Drives 0 05-26-2005 09:09 PM
software choice mackenzie General CNC (Mill and Lathe) Control Software (NC) 0 11-24-2004 09:46 PM
