| Hi, Not having worked with a CNC router before, i'm curious to the actual operation when it comes to the base board or table. Is it sacrificial? does it get all cut up when cutting through the work piece? I would imagine to get a get edge cut you would want to go a fraction deeper than the work piece, but then your cutting into your base. This seems fine if using a sacrificial board but what about if you have a vacuum table?? You wouldn't want to be cutting into to vacuum table and replacing that. Especially some of the aluminium ones i've seem here... If anyone can shed any light on this it would be greatly appreciated. Thanks Matt |
| From my experience with CNC, well actually with a Thermwood Router, the vacuum table has two layers of wood, MDF mostly, one is the initial base board about 16mm or so suspended on little what appeared to be nylon pegs spaced evenly apart for leveling consistency, then there's a "spoil board" about 5mm or so place on top of that, this is what takes those fractional cut through marks, the vacuum we used was so strong that it pulled "through" the surface of those two sheets, then your sheet to be cut is then placed on top of those and held down, i was amazed when i first saw this, couldn't believe that you could suck through a whole sheet of MDF like that and how it held in place, no need at all for any clamps, but bare in mind that using this method the edges of the 16mm MDF had to be sealed so the vacuum wouldn't leak through the edges, thus reducing vacuum pressure. |
| Thanks guys. Vacuum through the MDF with a thin sacrificial board sounds good. Couple of questions though... How do you connect the vacuum to the under side of the baseboard? How big an area can you use a vacuum through the MDF? I'm going to have a large cutting area (1400mm x 700mm). I'm guessing you need more than a domestic vacuum or shop vac.... |
| Here is a couple more for the list. http://www.onsrud.com/pdf/Spoilboard-4.pdf http://www.whitesiderouterbits.com/catalog.html -on this one just scroll down to the link that says "CNC Spoilboard Surfacing"
__________________ Robbie (Note: The opinions expressed in this post are my own and are not necessarily those of CNCzone and its management) |
| Vacuum table and vacuum pump | garagefela | DIY-CNC Router Table Machines | 19 | 01-25-2012 10:30 AM |
| Vacuum Table | CNCRob | Work Fixtures and Hold-Down Solutions | 146 | 04-15-2009 04:57 PM |
| vacuum table | dmglass | General Metalwork Discussion | 3 | 11-16-2006 05:46 AM |
| Industrial Vacuum table | osdhillon | DIY-CNC Router Table Machines | 6 | 10-24-2005 05:38 PM |
| Vacuum table | balsaman | DIY-CNC Router Table Machines | 11 | 01-05-2004 08:18 AM |
