3x4 is not small for unsupported 20mm rails. Expect a lot of flex.
__________________ Steve DO SOMETHING, EVEN IF IT'S WRONG! |
| Get the pre drilled ones so you can attach some supports. Thats is what I am going to use in my build. I will make some supports out of 3/8 in flat bar. I will mill a 20mm radius to mate with the rail and bolt it to my frame. Hope to have pics soon. |
| i am looking at doing basically the same thing. 20mm rails with the open linear bearing the rail will be supported at each end with aluminum support blocks and strip of either aluminum or mdf running under the rail to keep it from deflecting. i will probably use mdf for budget reasons. it should do the job good enough since they just have to sit there and support the rail. i wouldnt think the rail will be pushing down hard enough to deform mdf. |
| What about drilling an tapping for some support rods that could be welded to my metal sub frame about every 6inches. As I said earlier I would think its pretty tuff drilling into hardend steel never mind tapping oh my....This would eliminate down flex and side to side motion. Has anyone attempted drilling if so how did it go and what kind of bit was used....Thanks. |
| well i decided to go ahead and throw down another $10 per rod and go with the 60" drilled/tapped rods. and i guess i will make some support blocks out of aluminum to bolt to them. hopefully with that rod and decent supports there will be little or no flexing. |
#10
| I didn't see any info on their site for ordering them pre drilled and tapped....uugghhh...Well, I'll just have to attempt it myself...Thanks...any pics.....Just checked the site and there they are 3 pages from the 20mm section.... |
| DIY Linear Rails | JerryFlyGuy | Linear and Rotary Motion | 77 | 11-29-2009 05:48 PM |
| linear rails | lgalla | Linear and Rotary Motion | 5 | 02-08-2008 04:35 PM |
| How to cut linear rails | IQChallenged | Linear and Rotary Motion | 4 | 06-07-2006 06:20 AM |
| Linear bearing spacing & Sizing linear rails? | fyffe555 | DIY-CNC Router Table Machines | 3 | 12-07-2004 01:09 PM |
| Linear rails, rod which is better for cnc? | snokid | DIY-CNC Router Table Machines | 9 | 12-29-2003 07:12 PM |
