Old 03-05-2007, 12:32 PM
Toysrme is on a distinguished road
Cool Router suggestion
Would a ryobi panel router be OK for some mild wood projects, but mainly alot of cutting out 1/4" phenolic plastic?
Not too sure of the router choice. Other router recommendations are welcome also.
Old 03-05-2007, 09:20 PM
Regnar's Avatar
Regnar is on a distinguished road
I use a Rigid trim router and it works pretty good. Im not moving at a blistering pass either. The only one that I dont think would work is the ryobi battery trim router. Im not an expert but I dont think it has enough umph.
Just to give you alittle more about the Rigid. I just used it to cut some 3/4 Oak Plywood and did it at a 1/4 inch pass. I was doing this by hand so I cant give you and speeds. Oh and the bit was 1/4 endmill sprial upcut. I can say that it cut it like butter. Smooth but needed alittle force. For 80 bucks at home depot I couldnt beat it.
Oyeah some people use Dremel tools I think it just a matter of how fast you feel like going and how deep you want to go.
Old 03-10-2007, 07:36 AM
CurtisU is on a distinguished road
Speaking of router choice...
Which of this style of "spindle" offers the most flexible collet or chuck?
I'm using the Hitachi (1/4 or 1/2 inch bits) but would consider purchasing if I found a router with a 1/8" and 3/8" capacity. I think someone mentioned the Porter Cable as having a 3/8" collet available, are there others (codeword cheaper)?
What are the rest of yous guys using?
Curtis
Old 03-10-2007, 07:42 AM
ger21's Avatar
I don't think you'll find anything cheaper. Yes, you can get 3/8 collets for the PC. for 1/8" bits, you can get 1/4" to 1/8" adapter bushings. Another option is to get an ER collet chuck. Not cheap, but you can get collets from 1/64" and up.
http://www.use-enco.com/CGI/INSRIT?P...PMAKA=891-7168
A suggestion shreifali General Metalwork Discussion 0 02-05-2007 08:44 PM
CNC parts to buy suggestion avengine CNCzone Club House 6 04-20-2006 09:45 PM
A suggestion and a thank you.. murphy625 Suggestions for the CNCzone.com site. 1 03-05-2005 07:02 PM
Trying to use G92 Y* as per everyones suggestion but...... Darc CamSoft Products 10 11-26-2004 04:33 PM
New guy and I need suggestion. dmgdesigns DIY-CNC Router Table Machines 7 01-31-2004 05:29 PM
