Old 02-28-2007, 08:37 PM
justCNCit is on a distinguished road
Reid tools, acme nut & rod.
I have their catalog, parts AR-23 and AR-3. What do you guys think of them, they are 1/2" 10 TPI rods & nut combo. Will they give reasonable performance on a large wood router. Also, what do you think of the using a clamp style flexible coupler out of the rear of their catalogue, of the 3/8" to 1/2" mate variety.
The configuration would include a motor off of Xylotex( the 260 oz in one), with a shaft coupler/spacer machined custom that would mate the 1/4" motor shaft to the 3/8" coupler bore, the coupler having a 1/2" bore on the other end, then slide the threaded rod into that bore, bearings to the rod.
sorry for the sloppy drawing, only drawing program I have right now.
Old 03-01-2007, 12:13 AM
SCHootie is on a distinguished road
If I'm understanding you correctly, the couple looks to be a Lovejoy type coupler. If it is, you can just buy a 1/4" bore-spider-1/2" bore combo. Total cost about $5 or $6. You can get them from ENCO, McmasterCarr, etc.
Old 03-01-2007, 10:40 AM
thanks.
Old 03-01-2007, 08:23 PM
That link is a real life saver, McMaster-Carr is the winner of the day.
Old 03-02-2007, 01:04 AM
If you're looking for acme screws as well, at least check out use-enco.com .
They have 6ft acme screws for $6.99. That is 1/2" 10tpi. If I saw correctly on reidtool.com, they were $45.00 apiece. You could buy your lead nut separate and still come out ahead. I know you can buy the lead nuts on dumpsters.com for $15 apiece. Don't know where Enco is located, but I ordered my screws Monday morning and they got to my house Wednesday morning. Fast.
Old 03-02-2007, 04:39 PM
the stuff that McMasterCarr sells is precision, though.
Old 03-02-2007, 04:42 PM
ger21's Avatar
Look at the Keystone precision acme at www.msc-direct.com very reasonably priced.
Old 03-02-2007, 08:16 PM
looking in their catalogue, can't seem to find a 3/8"-10 ACME Precision anti-backlash plastic preloaded nut. The nuts they do have, have some really odd pitches - 3/8 -4? 7/16 - 2? 1/2 - 2? what kind of preloaded nuts are those.
anybody know where there are reasonably priced, plastic preloaded ACME Precision nuts, preferably in the 3/8 - 10 range. Or any other similar suggestions welcome. .
Old 03-02-2007, 08:21 PM
braidmeister's Avatar
braidmeister is an unknown quantity at this point
www.dumpstercnc.com
Bring your own tools or does your company supply tools? ZipSnipe CNCzone Club House 10 02-04-2011 07:06 PM
Acme Internal Thread 1 ½ - 0.250P-2.000L-ACME-2G-LH (8 START) Help pandiyan.innova CNCzone Club House 7 11-16-2006 05:47 AM
KDN Tools jleiwig Benchtop Machines 13 02-27-2005 09:18 PM
What are these tools used for? OCNC General Metalwork Discussion 2 12-25-2004 08:31 PM
what acme tap do I need for the Enco ACME rod? AJ_Mac2001 DIY-CNC Router Table Machines 15 03-08-2004 07:24 AM
