Old 03-10-2004, 10:13 AM
junkmail is on a distinguished road
dual purpose cnc router
I am looking to build a medium sized router in the 24 x 36" or so range and want to be able to cut a variety of materials sucha as solid wood, particleboard, mdf, and aluminum (up to 1/2" thick). I now the wood and wood substates will not be a problem, but how about the aluminum cutting on the same machine? What design issues / changes do you recommend - short of 2 seperate machines?
I am consudering using the data cut plans with slight madifications - anyone else use these?
Thank all
Dan
Old 03-10-2004, 10:48 AM
Cold Fusion is on a distinguished road
I am doing almost the same thing as you. Here are my plans. 30x30 table.
Proud owner of a Series II Bridgeport.
Old 03-10-2004, 12:01 PM
InventIt is on a distinguished road
Re: dual purpose cnc router
Originally posted by junkmail
...wood, particleboard, mdf, and aluminum (up to 1/2" thick). I now the wood and wood substates will not be a problem, but how about the aluminum cutting on the same machine? What design issues / changes do you recommend - short of 2 seperate machines?
Dan
Dan,
The few major issues seem to be rigidity, mass, (which comes with a ridged machine) and type of bearings. You'll need a heavy ridged machine. The cutter bit will have a tendency to chatter as it cuts. Your machine needs to absorb that vibration. Don't skimp on the bearings. Use large Thompson supported rod or THK linear rails. Also you’ll need at least 30+ IPM to keep the cutter bit from loading. Of course coolant helps also.
I can cut alum my machine. You may want to check it out.
http://www.cnczone.com/forums/showth...&threadid=2249
Search CNC Zone for “aluminum” or “milling” or “end bit”.
Techno-Isel CNC router for sale? Noah Commercial CNC Wood Routers 5 11-27-2008 10:12 PM
2nd Generation CNC Router Design 32.5” X 14” X 6” gregmary DIY-CNC Router Table Machines 9 03-24-2005 04:46 PM
buscht's cnc router buscht DIY-CNC Router Table Machines 25 04-13-2004 11:43 AM
My first CNC router: 1.5 years building hddjohns DIY-CNC Router Table Machines 2 04-03-2004 10:18 AM
Budget CNC Router Blackhawk DIY-CNC Router Table Machines 24 02-21-2004 07:19 PM
