Ok, I know if I am going to try to do some motor sizing calculations I need to start with how much load I will need to push. It's a simple matter to measure the force required to move a table, but what do you guys use for calculating the force to move a router bit through wood? Now I know that's not a well difined question due to the different kinds of wood, bit size and shape and cutting depth. But let's assume a 1/4" bit diameter, moving though hard wood (maple/oak/walnut), and lets say a cutting depth of 1/4" (roughing cuts). I know to add in 40-50% safety margin. I'm just trying to come up with a good, general ball park figure to start my calculations with. Anybody care to offer up a number? Oh, and can I assume somewhere between 30 and 50 IPM as a cutting speed for my broad calculations? Thanks for any help ( I know it's not an easy question to answer). BobL. |
| I can cut this at 30-50 ipm, but you need to experiment to see what your machine can do. Too many variables in a shop built machine to know how well it can do the job without just actually doing it. Just try it. I have to adjust production speeds all the time to accomodate changes. I'm down to cutting at 50 ipm on my X now and it's down right depressing.
__________________ Steve DO SOMETHING, EVEN IF IT'S WRONG! |
30lbs, but with your example it would be considerably less. I saw the 30lb figure mentioned a long time ago. I'd shoot for at least 100ipm or more.
| Not rapids, 100-150 ipm cutting speeds
| what's suitable Stepper motor for cutting wood? | SeQueNcer | Stepper Motors and Drives | 4 | 08-03-2006 05:35 PM |
| Chip load and cutting depth. | SCCoupe | DIY-CNC Router Table Machines | 3 | 07-19-2006 02:24 PM |
| Cutting wood with OneCNC. | nagjames | OneCNC | 3 | 12-20-2005 04:54 PM |
| Sand/Bead Blaster wood cutting | DDM | DIY-CNC Router Table Machines | 13 | 12-27-2004 08:12 AM |
| Looking for cutting speed and feerate data in wood and foam | Trimix | DIY-CNC Router Table Machines | 1 | 01-20-2004 08:20 PM |
