I have noticed that most who have made cnc routers have chosen steel pulleys over poly/plastic pulleys. Is this because they really are superior, or is just a steel is better mentality, not based on anything else. I am highly considering buying the poly pulleys. Does any one have any thing to say about my purchase choice before I buy them? |
| Are you referring to timing belt pulleys? If your on a tight budget it may be worth saving a few $ to get the poly. Problem I noticed is 2 fold. One, the circumference is not true to the shaft. Two, the way there mounted to the hub looks weak. I wouldn't think you could put much of a load on the poly like you could on the alum/steel. I guess that depends on you design requirements Probably worth a few extra $$ to go with alum. And they look nicer |
| I replied earlier but something happened, don't know what. There is a site that uses plastic pulleys, look under reduction gearshttp://www.axxustech.com/Axxus4x8/axxus_4x8.htm |
| Machining Mild Steel | georgebarr | General Metal Working Machines | 5 | 06-29-2005 06:54 PM |
| Boring Pulleys | Moondog | General Metalwork Discussion | 9 | 12-14-2004 09:25 AM |
| Comparing aluminum extrusion to mild steel | coolman | 80/20, TSLOTS and other Aluminum Framing Systems | 2 | 12-10-2004 09:19 AM |
| Drilling hardended steel - update | DJ Morrow | General Metalwork Discussion | 3 | 11-29-2004 12:42 AM |
| why not steel? | NeoMoses | DIY-CNC Router Table Machines | 15 | 09-11-2004 09:14 PM |
