Old 02-20-2007, 12:12 PM
studysession is on a distinguished road
Question Spindle help
Hi -
I am looking for a small light weight spindle that is still very durable. I am building a 6 axis cnc router. Will work with wood and soft steel and aluminum.
I am having a hard time to decide on what to use. Looking for advice from the experts.
ID:	32167   Click image for larger version
Please check out my CNC blog
http://cncinside.com
Old 02-20-2007, 04:04 PM
srmaietta is on a distinguished road
cool drawings, good luck with the machine! Depending on the overall size of your machine, perhaps you could adpat an x2 or x3 mini mill head. Or maybe a sherline mini mill head? Might also think of trying a laminate trimmer and geraing it down maybe 3:1 with a belt or two, that should give you a good bit of torque, and with a variable speed drive, a good range of RPM's. The thing is that for cutting steel you need relatively low RPM's, and for wood you want high RPM's. Its tough to get that rnage with one motor. Since this is going to be fully custom you might think of having two diff spindles depending on what youre planning on cutting.
gotta tell us what size youre planning on making the machine.. XYZ envelope is a good place to start.
~Steve
Old 02-20-2007, 05:27 PM
Thanks - The drawing I pulled from another site though. The mill will have a cutting area a little bigger than 3 foot by 3 foot. Made from mostly 8020 extrusion aluminum from www.8020.net
The aluminum should be here by the weekend. I started using MDF but decided to switch. I want to do a full 6 axis machine. I have the motors and controllers. I am using Mach3 which supports 6 axis. Now just need to figure out which spindle.
Old 02-20-2007, 05:49 PM
ger21's Avatar
What's your budget? Maybe the smallest spindle from http://www.ekstromcarlson.com/spindle%20motors.htm
Probably about $1500 or so.
Old 02-20-2007, 05:54 PM
veteq is on a distinguished road
expensive
Hello,
maybe this will be helpfull,
from low price to plus:
pulley drive:
http://www.sherlineipd.com/spindles.htm
http://www.profimaschinen.de/spindel...eleinheit.html
http://www.finleyspindles.com/contactus.htm
http://www.setcousa.com/index.cfm?fu...B36703489C9997
non puleydrive
http://www.eltesrl.com/inglese/prodotti.htm
http://www.nsk-nakanishi.co.jp/en/in...imf_index.html
http://www.alfredjaeger.de/
regards,
roy bakker.
Old 02-20-2007, 06:50 PM
Thanks for the links - Some are out of my price range but does give me a few idea. Appreciate it.
Old 02-21-2007, 02:45 AM
toneV8 is on a distinguished road
Originally Posted by studysession View Post
I have the motors and controllers. I am using Mach3 which supports 6 axis. .
What kaind 6axis controllers and motors you have.
Old 02-21-2007, 10:24 AM
walter's Avatar
Gold Member
walter is on a distinguished road
Gerry, do you have any experience with these spindles? Are they US build or original Fimec?
Old 02-21-2007, 10:32 AM
ger21's Avatar
No idea, but I've heard they are reasonably priced.
Old 02-21-2007, 05:10 PM
walter's Avatar
Gold Member
I think one of the members bought one like a year ago... I have to find that person and ask a few questions.
Thanks.
ISO 30 Spindle wildcat Industrial Hobbies (Support forum) 114 12-18-2008 05:46 PM
Sweo spindle drive? new mill dead spindle Shizzlemah Fadal 13 12-18-2008 11:11 AM
interact 4 spindle drive won't turn on spindle 0041601 Bridgeport and Hardinge Mills 7 06-23-2008 05:51 PM
more rpms for spindle motor and spindle bob1112 Mechanical Calculations/Engineering Design 33 02-10-2007 01:01 PM
Just had my spindle reground by Spindle Grinding Service! Edster Fadal 30 06-16-2006 10:48 PM
