Old 02-17-2007, 10:57 AM
SCHootie is on a distinguished road
Dumpster AB lead nuts
As I have posted in another thread, I am considering using acme screws for my Solsylva build and someone recommended Dumpster AB lead nuts. I looked them up and it doesn't appear there is a convenient way to connect them to the gantry. I had thought about using two of these with the flat ends facing out. This would allow me to bookend these two nuts with a piece of angle from the bottom of the gantry. They are about $15 apiece and would like to avoid using four instead of two. I am also worried about doing it this way because joining them this way would put the two small ends facing each other and didn't know if this would cause a problem. Anybody have any ideas about using them this way? I also considered just using the regular metal ACME nuts from ENCO since the original plans use regular threaded rod couplers.
Old 02-17-2007, 11:56 AM
ger21's Avatar
I haven't seen the Solsylva plans, but you shouldn't need to use 2 of the Dumpster nuts per screw.
Old 02-17-2007, 12:51 PM
gmfoster is on a distinguished road
You need to rethink things. Basically you would want to mount the angle alum the nut is mounted to differently them mount the acme nuts in a hole or slot in the angle...
Garry
Old 02-18-2007, 05:50 PM
jsfjet is on a distinguished road
SCHootie
Just as a matter of interest what Solsylva router are you building? I am also building one of David’s designs however mine is the belt drive version
Regards,
Mark
Old 02-18-2007, 06:39 PM
boblon is on a distinguished road
Correct me if I am wrong, but at the bottom of the page where the DumpsterAB nuts are listed there is a link there for flange options:
http://www.dumpstercnc.com/leadnuts_flanges.html
Isn't this what you want for connecting them to the gantry?
BobL.
Rotating lead nuts Tom Brown DIY-CNC Router Table Machines 69 09-29-2006 09:25 AM
Yesterday's dumpster dive !! ZipSnipe CNCzone Club House 5 08-01-2006 02:25 PM
rfq s.s nuts mmurning Employment Opportunity 1 10-24-2004 12:58 PM
Nuts are driving me nuts! Cold Fusion CNCzone Club House 9 06-12-2004 11:40 PM
Nuts; I'm thinking about my nuts Stevie General Metal Working Machines 11 02-28-2004 05:55 PM
