Old 03-04-2004, 11:29 PM
ynneb's Avatar
Moderator
ynneb is on a distinguished road
Long Z axis machines
I am still thinking about the final design of my machine and am now considering a long z axis.
Lets say I wanted to route a wheel borrow shape for instance.
I am wondering if any one has made a machine with such a long axis, and how they designed it to be stable?
Old 03-05-2004, 12:36 AM
georgebarr is on a distinguished road
My first CNC machine has a long z axis. You can see pictures of it on:
http://www.cnczone.com/showthread.php?threadid=2865
The Z axis steel tube measures 36" and the z travel axis is about 24" to 30" ( I have not measured it). In order to make the frame stiff, I used thick mild steel beams. I welded some of the frame pieces together and bolted down the rest. Since this is my first CNC machine and I have not yet finished it, I do not know how good my design is.
Thanks,
Old 02-01-2007, 06:58 PM
gerry hanley is on a distinguished road
your best bet is build a vertickle machine it wood be more ridig
installing compound angled holes on 3 axis machines krustykrab Hard and High Speed Machining 8 10-13-2007 08:46 PM
4020 4th axis problems little bubba Fadal 3 06-13-2005 09:08 PM
No Encoder Counts On X Axis. Y=OK murphy625 CamSoft Products 5 03-08-2005 08:20 PM
2 axis to 3 axis conversion drembedded Bridgeport and Hardinge Mills 10 10-27-2004 11:32 AM
2.5-Axis vs 3-Axis JamesBond General Metal Working Machines 6 07-26-2003 07:09 PM
