Old 02-14-2007, 06:40 PM
bonehead is on a distinguished road
New CNC Router
Hi All
I'm planning on building a CNC router, What are your thoughts on the best CNC router plans on the net, I have been looking around for a while but I thought I would ask the pro's. I'm looking to build a 3 axis machine around 24x30x6 using servo motors and gecko drivers. and cutting out the frame work from aluminum.
any input would bee fantastic.
Old 02-14-2007, 07:32 PM
ger21's Avatar
For aluminum construction, look at the Data Cut. www.data-cut.com
Old 02-14-2007, 08:44 PM
dATA cUT
Tahk you for the replay, That is the machine that I thought would be the best choice. So Far.
Using a router for the 1st time. Need advice of cut speeds, router bits etc. Apples DIY-CNC Router Table Machines 19 09-23-2006 03:33 PM
Surfcam PP for Isel router / Precix router IvanTochev Post Processor Files 2 05-12-2004 12:27 PM
