Old 02-14-2007, 10:01 AM
DrPid is on a distinguished road
Z-Axis Counterweight/Spring Ideas?
The plans I purchased (Rockcliff) called for using a Dremel as the spindle. However, I purchased a Trimmer Router which weighs 3 times the Dremel.
Any Ideas on making a counterweight or spring attached to the Y-Axis to compensate for the extra Z-Axis weight? I am worried I will burn out my steppers.
I thought to use the springs in a window shade, as they are designed for large movement.
The return spring from a drill press are only designed for 1-3 inch travel.
A Bungie cord does not have consistant pull as it is stretched.
Old 02-14-2007, 10:20 AM
wamnet is on a distinguished road
here's my counterweight for a MAXNC:
http://home1.gte.net/wamnet/samples/maxextend.jpg
Old 02-14-2007, 12:38 PM
Cool, thanks for the input.
Old 02-14-2007, 04:18 PM
dan dimock is on a distinguished road
Joe's machine
You need to talk to Joe, he has the set up that you are looking for on one of his first. machine.
Dan
Z axis counterweight TPPJR Benchtop Machines 24 01-30-2009 08:39 AM
X2 Z axis Spring and Fusion CNC Kit Woodenspoke Benchtop Machines 5 02-05-2007 06:01 PM
5 axis mill design ideas BigAl1 General Metal Working Machines 6 08-25-2006 08:25 PM
4th Axis, need ideas PEU DIY-CNC Router Table Machines 3 07-04-2006 08:55 AM
need ideas on Y axis design toolbox82 Mechanical Calculations/Engineering Design 0 02-24-2006 07:40 PM
