Hi, I have followed hundreds of threads about gantry router construction, and am now designing one to be made of aluminum. I am planning on a 50" x 50" X & Y with about 6" of Z travel, and plan on using THK components. I will be machining my Router's parts on a Haas mill with 40" of X travel, so accuracy of the parts should not be a problem. The question I have is how do you get the Gantry (Y axis) to run a perfect 90 degrees to the table (X axis). I hear how some machines claim to have accuracy within .001 or .002, but they might be machining in a parallelagram? Even a mild twist in the Gantry from end to end would compound the error at the cutter. I can build the machine to make adjustments for this, but how do you measure to this .002 or so accuracy. If this has been explained somewhere else, please lead me to that thread. Regards, John |
A lot depends on the design of the machine. There is a big difference in ease of adjustment on a fix gantry machine VS a moving gantry machine in my estimation. There are likely to be a number of ways to square the machine but back when I ddi machine tools professionally we used a high precision Starret square and a dial indicator that could resolve well below 1000 of an inch. Install the square parallel to one axis of motion and adjust the other to run square to that axis. Dave |
| If adjustment can be made after the machine is completed, you could cut or edge 2 stacked pieces at the same time in a square pattern, then flip one piece upside down aligning the X edges and one corner. Then check at an adjacent corner for the error. |
You could always cut out a square and measure the diagonals. If they are equal then it will be square. If you're like me and don't have 24" calipers, you could always take a bar a aluminum 24" or so long, put a pin in one of the ends and put a lip on the other end to effectively lengthen your calipers. Since only the relative measurements of the diagonals matter, you could compare the diagonals of a 20" square using 6" calipers. -Matt |
| I went through this issue a few weeks ago, my machine is a bit bigger than yours and what I did was added elevation bolts at either end of the gantry, but cranking these I can lift either end as well as tilt the gantry forward or back. Then using the rail's I'd installed I leveled them two ways. Next the Z axis is made using THK type rails. I installed gib plates of sorts on each carriage, this allows me to again, tilt the Z axis two ways and gives me fine adjustment for the final alignment. These gib plates will have a small gap between themselves and the Z axis frame which will be filled w/ potting epoxy. To get your gantry sqr w/ the length of the machine, use a small v-bit in your spindle and mill [ I've a wood spoil board] traverse [along the x ] your mill while cutting a slight groove in the table top, you can then use a large compass to create arc's which center on the groove. Where the arc's intersect is 90Deg to the milled groove. You have to tram your mill to this line. Use a large machinist straight edge and a dial indicator to get it sqr all the way along. Then you can test some parts, measure w/ a caliper and tweak as needed. If you find a better way, let me know. I' haven't done the sqring thing yet, just the leveling part ![]() Jerry
__________________ JerryFlyGuy The more I know... the more I realize I don't (Note: The opinions expressed in this post are my own and are not necessarily those of CNCzone and its management) |
| Thanks Guys, You have come up with some good ideas. I figured anyone making a machine would have to deal with this. After hearing from you guys, I thought of maybe having a shop with a CNC mill with a relatively long X & Y travel machine 2 edges square on a plate, and then indicate the y out to that distance. That would make my machine at least as good as the CNC machine that it came from. Any more thoughts? John |
| Eson, I don't think your understanding the question. When you have a long Y axis [gantry], how do you know/ quantify the perpendicularity of the Y to the X axis? It's a fairly in depth problem. John, your sqr plate would work for sure, it might be a bit pricy to do however, depending on who you know in the industry, it might be cheaper.. all depending.. Jerry
| Using the router, you can also cut 2 slots in the table 4' between centers with the X axis(same as a slot as Jerry posted) off to one side of the table surface. Using the slots with keys dropped into them, and butt up an edge of 4' square material against the 2 keys. Now you should be able to cut along the Y axis edge, flip the square over maintaining the original edge against the keys and then cut the opposite Y axis edge. Measuring across the 2 Y cut edges should reveal an out of parallel or bow if the X axis reference edge is repeatable. It should become evident which way the gantry must be adjusted to make the Y axis parallel in this test. Although this does not take into account any twist in the Y axis rails. So confirm the Y axis does retain Z tram throughout its travel first. The 1/32 diagonal of a square spec on one of our smaller routers(dual servo rack and pinion) describes their process to adjust the homing switches since it homes each servo independently. You can watch it rack the whole assembly during homing about 3 times until it agrees each side is synced up. What a goofy POS! +/- .002 repeatability, my A$$! We are lucky if we can keep the parts within .015. Even that changes drastically in different areas of the table surface. DC
__________________ Learn cause and effect through experience. Mastering those relationships is the "Common Sense" ability within the art of any trade. |
#10
| DC, do you think I could convince you to do a sketch of your method for me? I'm missing something here. The way I read your description you'd end up w/ two parrallel grooves long the Y axis but they may not nesc be sqr to the X, just parralel between themselves? I'm sure thats not what you ment so I just wanted to get my head around this. I've still got to sqr my mill so any help I get here will be much appreciated! Thnx Jerry
#11
| Hi Guys, From what I have been reading here, it would seem that some sort of strict procedure should be determined to complete this square-up process. Perhaps something like the following: 1) Completely level the 4 corners of the machine. 2) Determine whether your Gantry is free of twist (However this can be done, possibly a precision machinists level?). 3) Adjust either the Table or Gantry Y axis for constant depth of cut (Assuming you already have a constant X depth). 4) Follow the "yet to be determined method" to square the Y axis. 5) Once squared, bore 2 holes for dowel pins into the table at each end of the Y travel so you can re-verify the squareness with an indicator in the future. I designed my Router to have the THK rails facing up on top so that I could have slots for tweaking and shims for twist correction of the moving Gantry. If there are any other Professional Router builders out there who have a viable method, and would not mind sharing it, please post here. Regards, John |
#12
| Here is a pic to show some detail. Cut the slot or key slots in the X axis spoil board first. Place a good left edge (perfectly straight) of the test piece against the keys. Then cut the lower edge with the Y axis. The sheet must be then be flipped over to cut the second edge of the test piece, with the same original edge butted against the keys. The first Y axis cut will now be at the top of the test piece since it was flipped over. Taking the second cut on the lower uncut edge with the Y axis on the test piece. Measuring the parallelism between the 2 Y axis cuts will show up in the test piece. The perpendicularity and straightness of the 2 Y axis cuts are amplified from flipping the part over in reference to the X axis keys. Flipping the sheet over and reseating it against the keys must be done in a manner that keeps the material against the keys. Any glitch that might shift the test piece(during fastening or cutting) into or away from the keys can throw off the test results. So the keys must be tight and be aware of any chips between the reference edge and the keys. DC
| Moving a part: which method | originator | Linear and Rotary Motion | 0 | 11-02-2006 11:19 PM |
| What method will be more accurate? | DennisCNC | Mechanical Calculations/Engineering Design | 9 | 09-01-2006 05:44 PM |
| Can someone tlee me how to square me gantry? best way? | Apples | CNC Plasma and Waterjet Machines | 3 | 09-24-2005 08:30 PM |
| Best method to make this | Moondog | General Metal Working Machines | 14 | 10-07-2004 05:49 AM |
| Best Method | musky2much | WoodWorking | 1 | 10-13-2003 08:59 AM |
