Old 02-12-2007, 10:16 PM
jayty97 is on a distinguished road
Looking for a little guidance!
I am new to this site and have been reading through some of the great info. I'm sure everything I will need to learn, I can find here.
I have decided to jump in head first and build myself a 3 axis machine. I build custom woodwork of all types and for the most part want a machine to make custom grills out of solid wood and thin aluminum plate and simplify inlay work, but also want the capability to do some 3d wood carving..... and maybe an aluminum part or two every now and then. There will be a lot of common designs, where I'm hoping a machine like this will be indispensable.
I am currently trying to expand my business from a small 1 person shop, so am definitely on a somewhat limited budget. Overall I think a 2' X 4' cutting area will be ideal with a 6" or so z. I want to do it right and build a reliable machine, but also want to keep it as simple as possible. Precision probably only needs to be moderate.... I guess good enough to make clean cuts in aluminum. considering what I will be using it for the tolerances don't have to be the highest. I am definitely leaning towards all welded steel construction. Weight isn't an issue as it will sit on a concrete floor, actually I think the heavier the better with a tool like this. I will probably purchase a pile of surplus steel from a local supplier to start with. I think I want to go with a gantry arm construction, servos for the drive. controller....and everything else, I'm trying to figure out.
I definitely need something more powerful than a dremel or rotozip, so am thinking a 3 1/4hp router.... especially after looking at prices of spindles! Ive looked at prices of ready built machines and anything that is of any quality is out of my league. This is also something that I need to jump into and get the job done, that concept has never failed me before! I have a bit of knowledge in all the areas it will take for the build, from the fabrication end to the computer side of things, but am certainly no expert, so am looking forward to the learning experience and tying various skills together.
I have access to a machine shop if needed.
Any and all information that can put me on the right track will be much appreciated. I know it is probably here somewhere. I think the only problem with this site (if I can really call it a problem!) is that there is just too much good information!
I don't work from set plans very often and find most of my best work comes when I just wing it, so want to find a happy medium with this project, sticking with a good general plan, but still throwing enough ingenuity in the mix. I'm definitely not entirely looking for a plan to copy.... that's no fun. I want to take in a bunch of good ideas, mix them with my own and make it happen.
I will do my best to take many pictures along the way and post those as well as notes as things come together. I am a fan of the take a penny, leave a penny strategy, and will do my best to pass my acquired knowledge on and maybe a few wacky ideas along the way. For now though I need to act as a sponge and suck in all the info I can before the initial leap. Please give me your opinions, links to posts, parts selection, servo sizes, controllers ...ect.
Thanks, Jay
Old 02-13-2007, 10:54 AM
dan dimock is on a distinguished road
same boat
I am in the same boat that you are in, I am taking parts of three plans that you will find here and building one to do what I need. If you will go to the site on wood routers and them the site where they post the build it log, you will find a lot of information. Lion Claw has just complete a machine that is about the size you want. If you have any problems finding the links, let me know and I will look them up for you.
Good luck, and keep us posted, I may want to copy yours.
Dan
Old 02-13-2007, 01:38 PM
Thanks for the reply Dan. I'm still working my way through that section, which I found last night. There is just so much info. The one thing I see a lot of is people using wood for their main structure. Something just does not sit right with me in thinking that a machine built in that manner will last and stay accurate enough.....maybe I'm wrong. I'm thinking a solid 1" thick base plate..... a 1000lb machine... am I crazy? or is there really a better way? I am seeing some projects done in steel as I pan through the posts. It's definitely great to see the many ideas out there being shared.
Jay
Old 02-14-2007, 08:43 PM
blaz72282 is on a distinguished road
Hey, I'm mike and I was in the same situation a few months back. So much info available, its hard to sort through and get straight answers. Don't let it get to you. First, I would read through the forums for at least a few weeks before you begin planning or building. This will get you familiar with the terms and different designs available.
Many people here use wood as their structure, and these machines are usually intended to cut wood, plastics, and other soft materials. For aluminum and harder materials, a stiffer metal frame structure is definately the way to go. However, I've learned that heavier is not nessecarily better. Rigidity and stiffness is most important and can be achieved with less materials and good design. And as for designs, I would view lots of people's machines, and develop your own design that will best suit your needs.
I also did'nt have a detailed plan to start with when building. I've seen many times on this forum that folks new to the cnc bug end up taking months to slave over a perfect design on paper, and then find that their design may not work, or even worse, they get bored and never build it. I suggest making rough drawings and measurements, and start building. Plan as you go. Thats the route I took and I am 1/3 completed with the build portion of my machine.
Anyway, Sorry if my post is long and rambly, but hopefully I can share my tips and experiences to help others out. -Mike
P.S.-My machine is steel frame const./24"x30"/3hp VS router/ Mainly for cutting aluminum. I will be starting a build log soon, as time allows, so look out for it!!
Overwhelmed, have many parts... need guidance Darren DIY-CNC Router Table Machines 67 11-21-2007 12:49 AM
Newbie looking for guidance yellow CNC Plasma and Waterjet Machines 1 09-14-2006 08:40 AM
In need of guidance xcphil General Metal Working Machines 0 05-29-2006 01:41 PM
I need a little guidance please.... Steve F Servo Motors and Drives 5 05-15-2006 01:16 AM
Need some CNC guidance seafire CNC Plasma and Waterjet Machines 2 11-15-2005 10:07 PM
