Old 02-11-2007, 03:58 PM
audioandy1762's Avatar
audioandy1762 is on a distinguished road
Design Help Please
Hi All
I am in the early stages of designing my mill and was wondering if one of the more experienced among you, would have a look at my drawings and see if I am on the right track.
The bearings used are Hiwin HGH-HA 25mm rails and carriages for the Z and X axis, I have 30mm version for the Y axis (not shown in the drawings yet).All the mounting plates drawn so far, are all that I have had given me along with all the bearings which is 16mm thick aluminum and pre-drilled to take the rail and carriages. I should end up with about 700mm of travel in the X and Y axis and would be happy with 200mm in the Z.
I have used Autocad 2004 which again I am self taught through reading books and just using it, so if I have done something that’s not quite right I would be grateful for any constructive criticism.
Andy
PS Hope this is in the right forum sorry if its not
Old 02-11-2007, 04:44 PM
svenakela is on a distinguished road
Without looking at the drawing I guess it's a router, so I moved this thread to the DIY Router forum.
Welcome and happy posting!
C'mon out there, give Andy a hand will ya!
Old 02-11-2007, 09:06 PM
ger21's Avatar
When the Z axis is fully extended, you might get a little flex. What do you intend on cutting with this? Also, the spindle mount looks a bit weak.
What you're calling the X axis, I'd call the Y. And you probably don't need 30mm rails for the gantry to ride on. Overkill.
Old 02-12-2007, 06:42 AM
Hi Gerry
Thanks for the reply I was hoping that the way I intend to mount the Z axis, bearing carriages fixed, with 320mm of rail supported at full stroke of 200mm it would reduce the flex.
My initial idea for a CNC router was to make PCB’s but after finding this site and seeing all the other interesting stuff people are doing I would like to think it would be ok to use on wood and maybe aluminium. The spindle mount was drawn quick just to show the front face of the Z axis I do intend to beef this up somewhat.
The view in my drawing is looking at the front of the gantry, I thought that left to right movement was the X axis and front to back was the Y, have I got this wrong?
As for the bearings I have had them given to me, they were removed from a piece of redundant kit that had done very little work and was destined for the skip! 4 x 30mm carriages 2 x 30mm rails 2.6 meters long!
After looking at my drawing and me clarifying a few points, am I on the right track to making a half decent router or should go back to the drawing board?
Andy
Old 02-14-2007, 04:54 PM
Cool
Well I will just carry on the way I'm going and hope it turns out ok.
Andy
Old 02-14-2007, 06:34 PM
Oldmanandhistoy is on a distinguished road
Hi Andy,
Have you got a job in mind that needs that much Z movement or are you just covering all the options?
The reason I ask is you mentioned milling aluminium so you need all the rigidity you can get. Reducing the Z movement will increase the rigidity.
Other than that I see no problems with timber products with your design as is.
Are you designing this machine as a hobby machine or do you want to use it for commercially?
John
Old 02-15-2007, 01:54 AM
Hi John
Thanks for the comments, no job in mind I just thought with those bearings and the ball screw I have I would get the most out of them, what would you say is a practical Z movement.
It is only an hobby machine.
Andy
Old 02-16-2007, 06:33 AM
Originally Posted by audioandy1762 View Post
Hi John
Andy
As this is a hobby machine I would say go with the Z as is; you could always change it if you have problems or you want more rigidity. The way to compensate in your situation is to reduce cutting speeds which is not a problem for a hobby machine but this may still not be enough for milling aluminium.
I would say have a very hard think about what you will be cutting and reduce the Z height to a minimum. Or you could design in a way to adjust the height of the Z for the rare occasions you need the extra.
Be sure to start a thread in the router project log section when you make a start on the build. I am no expert but there are some very knowledgeable members who will keep you on the right track.
John
Old 02-16-2007, 05:08 PM
Hi again John
I will take on board regarding designing an adjustable Z axis, I was also thinking about maybe lifting the work piece up towards the cutter.
One of the reasons I am building a CNC machine is to manufacture cases/boxes to house my audio projects, it would be nice to have the facility to accurately drill along the edge of a side piece of an enclosure to fit a top and a bottom.
I intend to start a thread once I get going, the electronics side of things is almost complete, I am using Gecko 210’s running Nema 34 steppers at 48v 4amp,( got the above working with help from Jerry CJL5585) as you say a lot of knowledgeable helpful and friendly people on here.
Thanks again
Andy
Please help with CNC design nsiters DIY-CNC Router Table Machines 3 12-28-2006 11:35 AM
Could someone look at this design? candle DIY-CNC Router Table Machines 34 09-23-2006 04:10 PM
CNC Design Help bprzybyl Mechanical Calculations/Engineering Design 39 05-12-2006 06:00 AM
New to CNC design and need BIG HELP piashaw DIY-CNC Router Table Machines 3 07-19-2004 05:10 AM
Cam design??? anoel G-Code Programing 8 01-09-2004 08:06 AM
