Old 02-08-2007, 08:52 PM
powerfade is on a distinguished road
Servo runaway
So I purchased the Rutex 2010 drives about a year ago..My setup is rutex 2010 drives with 1000 line US Digital encoders and Mach 3. Everything has been working great for the past year. However, I went to jog the machine today and when I turn on the power to the motors the Z axis rammed right into the table top, I think I need to adjust my limit switch. I checked my encoder connections and they seem to be fine. Could this be a card issue or maybe an encoder issue? I was hoping someone might be able to shed some light on this. Thanks...
Old 02-08-2007, 09:09 PM
Gold Member
CJL5585 is on a distinguished road
Probably a card Issue.
The servo needs a signal to move. The encoder sees the movement and sends pulses to indicate that the movement is/Has taken place. So if you have movement when applying power to the unit, I would suspect the card as the first source of the problem. The encoder would be suspect number 2.
Jerry
Old 02-09-2007, 10:44 PM
Thanks Jerry....The problem was with the card. I swithced it out with my x axis and it worked fine. Sent it off to Tom at Rutex today. He is going to take care of it for me.
Old 02-10-2007, 08:16 AM
Gold Member
It was most likely a shorted output driver on the card.
Jerry
Servo drive / Servo Amplifier Ken_Shea Servo Motors and Drives 9 07-10-2007 05:12 PM
Fadal runaway problems? REVCAM_Bob Fadal 13 05-20-2007 07:05 AM
Problems with CNC Mill - Runaway Errors JMFabrications General Metal Working Machines 5 03-22-2006 02:56 PM
Servo Runaway bgolash Servo Motors and Drives 4 02-15-2006 07:00 AM
a.g.e. 3, z axis runaway condition lesnesman Bridgeport and Hardinge Mills 5 11-26-2005 08:36 PM
