Old 02-07-2007, 12:17 PM
santiago lisboa's Avatar
santiago lisboa is on a distinguished road
need help with 8010 t-slottedlinear bearing
Hi:
I work for a recycling CO. I will like to know if linear berings fot t-slotted frames are good or can be use to built DIY rauters and others.
See pict.
Thanks,
Old 02-08-2007, 12:07 AM
crocky's Avatar
crocky is on a distinguished road
They are supposed to be okay, there is a machine with those type bearings fitted and he reckons they are fine: Look in the 80/20 forum!
Bob
Old 02-08-2007, 09:36 AM
Thanks,
I will ck on the 8020
Old 02-08-2007, 10:16 AM
jgro's Avatar
Gold Member
jgro is on a distinguished road
or here: http://www.cnczone.com/forums/showthread.php?t=12202
jgro
Tapered roller bearing vs. angular contact bearing boyvox Linear and Rotary Motion 12 01-25-2007 02:49 PM
Bearing sala84 JGRO Router Table Design 7 11-03-2006 09:42 AM
Need Help Identifying a Bearing lerman Mechanical Calculations/Engineering Design 5 10-08-2006 09:38 AM
Linear Bearing tekno DIY-CNC Router Table Machines 6 06-29-2004 03:55 PM
Bearing in MDF Photon DIY-CNC Router Table Machines 6 05-20-2004 04:18 PM
