Hi all , I'm fairly new to this site and reading some of the intresting projects I got the bug and started building my first machine . I have some questions for you guys I bought 6' of Acme 1/2-10 lead screw, but machining it I noticed the metal is VERY soft , Should I use it like this ? I mainly want the machine to cut foam (lost foam casting) and maybe some wood what size stepper motors should I buy ? and where is a good place to buy them ? If you guys see anywhere that may be making a mistake I would really apreciate your advise Thanks Frank Martin Here are some pictures of my progress I hope to end up with a cutting area of 12" X12" X 2.5" |
| Well I made a little progress Finished up some of the table Made the electronics panel with a Xylotex 4 axis board and 2 solid state relays . I downloaded Mach3 and and hooked up the X and Y motors and everything was working perfect , I then got exited and started to hook up the Z motor and thats when the sparks started !! .I forgot to turn the power off on the panel and two wires touched my table , needles to say I cooked the driver board . So I ordered another board Here are some pictures , The cables need a better solution |
| frank thats pretty much what im wanting to build...but i cant make up my mind ive looked at alot of machines ,your looks pretty close to what i wanna build ,i was wondering about flex do you have any way to test for flex along your x axis? and what size rods did you use...are they hardened rods?.. hope you can give us some pics of what ever you plan to cut with it..great lookin machine !!! |
| Measuring Flex with a dial indicator the Gantry Flexes .003" and returns to .001" . There is a small amount of hysterisis , but its better then I had expected. The Shafts I bought as a kit on eBay from these guys http://www.web-tronics.com/cncrodkit3.html They are 20mm ,16mm and 12mm The threaded stock I bought here: http://www.dependableacme.com/about.htm Glad you like the table , its been fun learning as I built it. I got another board from Xylotex and just bought the Mach3 software . I'll post some pictures of my test runs Frank |
Hi there i've started a gantry type router, after collecting bits for 2 years i have finally started welding bits together. the plan is to have a tubular steel frame MIG and TIG welded and cross braced for total rigidity. The spec of the machine: 3 Axis gantry miller with 280 x 900mm bed, 400mm Y travel, 1100mm X Travel, 400mm Z travel. I already have 6 x 12 x 600 x 4mm ballscrews for the Y and Z (2 spare), 1 x 25 x 1100 x twin helix imperial pitch ballscrew. the basic idea is to have the Y axis moving back and fore on the base of the machine, the X along the gantry as normal but for the Z axis the entire gantry will move up and down. The problem i'm going to have is counterbalancing the 30Kg mass of gantry and spindle motor. my first plan was to have cables and counterbalance weights on the side of the machine, but this wouldn't counteract the movement of the spindle. so i think i'm going to use pneumatic assistance i'm not quite sure how this is going to work out but i have some spare linear air actuators so i may as well try! I was very lucky to be in the right place at the right time, in work they were scrapping of some old SMT placement equipment and this had loads of goodies in it including a kollmorgen brushless servo motor and complete drive system, altogether is will make an awsome spindle drive at 1.3Kw position and velocity controlled very cool. The only bug bear is that the factory set limit on the motor is 1900 RPM the motor max is 3800 so i have to find a way to remove the speed limit. Does anyone have any experience of kollmorgen bds5 servo drives? |
| Well I got it back running I've been playing with the Mach3 processor , What a buy !! . As I'm sure you guys already know Mach3 is great. I've also been trying out some of the sample CAM programs , this picture is a carving I did with Vcarve , its a neat program but the price is steap , I may still buy it . I am intrested in Solidworks to CAM if anyone has any cheap Ideas. |
For 2.5 dimensions it is free to export your files as 1:1 drawings and save them as .DXF's. Then use cambam to generate gcode.
__________________ Mark -------------------------- Check Out My Build-Log(s): http://cnczone.com/forums/showthread.php?t=4716 CNC Router Version 1 [====================] 100% http://cnczone.com/forums/showthread.php?t=39294 CNC Router Version 2 [=|-----------------------] 5% |
#10
| BTW . i've been playing with CamBam also , I wish I knew enough to help with the development . |
#11
You might have to make drawing first, than you can save as .dxf Not too sure, but might work |
#12
| Also, when creating the drawing you may have the use a custom sheet size and use a 1:1 scale for your drawing.
| CNC mill questions - thrust bearings, leadscrew mounting, general questions | tonofsteel | DIY-CNC Router Table Machines | 8 | 02-03-2012 03:42 PM |
| It's started | Max-DK | CNC Wood Router Project Log | 2 | 02-03-2008 08:45 PM |
| getting started in CNC. need all the help i can get :) | slow_rider | Benchtop Machines | 13 | 10-22-2006 11:42 AM |
| Questions about getting started | tyler_derden | General CNC (Mill and Lathe) Control Software (NC) | 0 | 10-06-2005 04:25 PM |
| New and trying to get started | robe_uk | Mechanical Calculations/Engineering Design | 0 | 04-17-2005 12:52 PM |
