Old 02-05-2007, 11:53 AM
jaredp is on a distinguished road
Newbe: how do I handle I/O
Hi, I'm planning a PCB router machine. I like the HobyCNC stepper packages with Mach2 software, but I'm trying to figure out how to interface extra I/O to the system. Anyone have any suggestions?
Old 02-05-2007, 03:27 PM
Guldberg is on a distinguished road
You need more than the 5 in and 4 out? I had a velleman usb experimental board lying around, i tried it in mach, with a bit of vb script you can make it work. It has 5ins and 8outs
Old 02-05-2007, 04:33 PM
Thanks, I want to build a tool changer (reason fot the I/O). I'll check out the USB boards.
Old 02-05-2007, 05:39 PM
phomann's Avatar
phomann is on a distinguished road
Have a look at the ModIO.
http://homanndesigns.com/store/index...&products_id=4
It expands the number of inputs and oupts you can control. Additionally, multiple ModIos may be controlled via Mach.
As to a tool changer application. I have added a toolchanger modules into the ModIO, including Emco PC50 lathe toolchanger , a Mazak lathe and for my own Asian Import lathes toolchanger.
There is a short movie of the Mazak lather toolchanger working in the files section og the Yahoo ModIO group at;
http://finance.groups.yahoo.com/group/modio
Also, I'm happy to add in custom toolchanger modules to the ModIO if required.
Cheers,
Peter.
Homann Designs - http://www.homanndesigns.com
newbe with ????'s Rods UP 9000 Benchtop Machines 10 01-04-2007 09:22 PM
Vb.net newbe GaryR Visual Basic 5 12-13-2006 07:23 AM
How much weight do you think it can handle? protrxrptr17 General Metalwork Discussion 7 12-01-2006 02:54 AM
CNC JR ? (Newbe) 70RTRacer Benchtop Machines 4 02-23-2006 05:26 PM
Knife Handle wjbzone WoodWorking 0 08-17-2005 11:10 AM
