Old 02-26-2004, 08:54 PM
ezland00 is on a distinguished road
Newbie question on drill bits
Hello all,
I did some search one ENCO, but i don't know which kind of drill bits will work on aluminum. I brought a drill bit earlier, but i didn't know it was for drilling ground or wall.
Please help me to find the drill bits.
Size:
1.25"
.75"
.25"
thank you
Old 02-26-2004, 10:31 PM
Gold Member
Ken_Shea is on a distinguished road
Aluminum is pretty forgiving when drilling, most any HSS (high Speed Steel) drill bit will work fine, either 118 or 135 degree, split point is standard now days. Be frequent in bringing the bit out of the hole to remove the cuttings. I would stay away from reduced shank if at all possible.
What equipment are you using to drill with?
1.250 is quite a drill and would be quite expensive, you may find it easier to drill say 3/4" then bore it on a mill.
Ken
Old 02-27-2004, 05:44 AM
i'm using drill press.
Old 02-27-2004, 07:17 AM
InventIt is on a distinguished road
If your drilling deep holes into alum. the chips will have a tendency to "stick" to the bit and not come out of the hole, therfore plugging the bit. This can be reduced with some lubricant while drilling. Also, Tin coated bits may help with drilling alum.
I ALWAYS use a coolant when drilling steel or other hard metals. Although it's messy, your drill bits will last ALOT longer.
Old 02-27-2004, 02:53 PM
thanks for the tip
Newbie question: how do I machine this? (Drawing attached) Aegeon General Metalwork Discussion 20 12-04-2005 01:20 PM
Bridgeport mill newbie question... GalaticDan Bridgeport and Hardinge Mills 3 06-06-2005 02:02 AM
Stop Bits, Parity gar Computers and Networking 4 06-04-2005 02:10 PM
What type of drill bits for lathe? James04 Machine Problems, Solutions , Wireless DNC, serial port 9 05-19-2003 01:37 PM
What type of drill bits for lathe? James04 General Metal Working Machines 15 05-10-2003 12:59 PM
