Old 01-29-2007, 10:29 AM
WI_HUNTER_DAN is on a distinguished road
2 drive motors for 1 axis
I see lots of cnc routers for sale with two drive motors on the X axis, who would you drive those motors? I assume you can use a three axis controller board and a Darlington array for two motors accepting the same commands is this right?
WI_HUNTER_DAN
Old 01-29-2007, 10:35 AM
joecnc2006's Avatar
www.joescnc.com
joecnc2006 is on a distinguished road
Normally, you use a 4 axis board and slave the drives in software, or another option is use one motor and the use a belt drive to connect to the two leadscrews.
Joe
Old 01-29-2007, 07:11 PM
digits is on a distinguished road
Joe
Is there a good reason why you can't use 2 drives but tie the step and direction pins together so that they look like just one drive to the software?
Old 01-29-2007, 10:02 PM
joecnc2006's Avatar
www.joescnc.com
I tested it with mach and worked but i used a 4 axis drivers, because each drive will need to be powered individually, I just jumpered the step and direction from breakout board.
Joe
Driving two step motors off one drive Davidh Stepper Motors and Drives 2 10-23-2006 02:55 PM
Can G202's drive these motors ?? richyrich212t Gecko Drives 3 03-25-2006 09:35 PM
5 1/4 Floppy drive Stepper Motors High Seas Stepper Motors and Drives 9 03-17-2006 03:33 AM
can brushless drive drive brushed motors ? max_imum2000 Servo Motors and Drives 2 02-09-2006 08:35 AM
2 motors 1 drive Fozzy Gecko Drives 0 04-04-2005 01:18 PM
