| I've been thinking about filling aluminum extrusions with concrete in order to add mass and stiffness. I figure a strong mix with high ratio of portland & very little water, rammed in hard would minimize shrinkage & warping. You could even add rebar and/or steel mesh for extra measure. Got the idea when I poured the footings for my new shop a couple of summers back. I'm going to run a test on a 40" long section of 2"x6"x0.125" commercial aluminum door frame. Has anyone else given it a try? Chris |
| How about filling it with sand? This is what the speaker guys do to reduce (damp) vibrations and add mass. Since the sand is removable...it'll be easier to move your router if you ever need to, just drain the sand out. You won't have to worry about the stress caused by differing expansion ratios of concrete vs aluminum. |
| azsigns: Why bother with that? Just build it out of steel like the CadCut CNC Router. 500 lbs of steel is better than aluminum no matter what you do with it. 2" square steel is cheaper than aluminum T-slots, it gives much more weight and is very rigid. Plus, it's fun to weld together! Of course, I'm currently using aluminum T-slots on my current machine but it is because I want it to be light, portable, and storable. But if you just want to add weight to somthing already made, I like biomed_eng's idea about sand. That would work well and it is reversable! |
| When I'm not learning about CNC stuff, I ride motorcycles long distance and long hours. 1000 - 1200 mile days are not uncommon. Handlebar vibration can be an issue so dampening becomes a topic of conversation. Some riders fill their handlebars with really small lead shot. I've never used it but I think they get it from places where you get shotgun shell reloading supplies. I've been thinking about using aluminum extrusions for a CNC frame and if you buy the larger extrusions, they sometimes have a decent size center cavity. I figured I'd use shot for that. Some riders mix it with some kind of resin or a bit of RTV to keep it from rattling.
__________________ David J. Morrow |
| Thanks for the feedback. I like the sand idea. I'll try it in my existing tables frame. The way I see it a machine can't have to much power or weight! I was also thinking concrete would make a good strong base for the smaller machine I'm building for engraving aluminum. Thanks Kong for the link to Isfoils machine. That's just what I was thinking of doing. Chris |
#11
| As for me, I went to my local hand gun club and asked if I could take a couple of buckets with lead from the shooting range. And they were just happy to get rid of it since it cost them money to send it for recycling. I can tell you, a bucket with lead is heavy! Regards, Sven |
#12
| Hey, I would go with polymer Concrete like Boros said, it not only is a better vibration dampener than cast iron, it is also self-leveling and relatively cheap. It is what most gantry type CNC manufacturers use nowadays. Unlike sand, it wont move and settle either. It will make a great bed also ![]() H3ndriX |
| Finding The Right Router | Crushmonkey | Commercial CNC Wood Routers | 22 | 06-19-2006 01:17 AM |
| long term stability of wood framed router | dave925 | DIY-CNC Router Table Machines | 17 | 05-05-2005 11:33 PM |
| Almost done with 1st Router project..phewww | Beezer | CNC Wood Router Project Log | 42 | 03-27-2005 05:39 PM |
| buscht's cnc router | buscht | DIY-CNC Router Table Machines | 25 | 04-13-2004 11:43 AM |
| CNC Router Frame | Firemanz84 | DIY-CNC Router Table Machines | 5 | 02-27-2004 05:52 PM |
