Hi guys, Christmas project was to design and build a cnc router, I live in perth Australia so I was able to get some local expertise as well. It works beyond my wildest imagination, Ive since construction, built, intarsia items, clocks, cut aluminium, made a wooden clock gear endless amount of plaques ect, it blows me away how versatile these things are. Heres a photo of the unit and a quick photo of a clock gear I gave a go, the gear is 9cm external dimensions with 64 teeth. The cnc unit is 820mm wide gantry and 1100mm long bed |
| Very nice, impressive work!
__________________ (Note: The opinions expressed in this post are my own and are not necessarily those of CNCzone and its management) "If the women don't find you handsome, they should at least find you handy" -RedGreen show. |
| yeh the gantry is 160 mm x 10mm plate alloy and the lower section of the gantry is a 100mm plate with the ballscrew between them. The base section is all 10mm steel construction on a 40x40mm box steel trolley which houses the computer and electrics. The z axis is a milled 100mm x 25mm plate of alloy gutted for the ballscrew. Heres a couple more photos of little jobs done already first is some alloy vent holes next is a clock with routed pocket in back for clock mechanism and bored hole for temp gauge, and the next is a piece done for intarsia |
| I did that as a test unit to see whether its possible or not, so I used craftwood and used a 3/32 end mill cutter with a feed speed of 90, material thickness was 3mm, passes were 2mm. A hardwood would come up a lot better because there nice clean cuts. Ive always wanted to make a wooden clock, so It was a test piece for maximum teeth minimum size. You couldnt use larger than a 3/32 in this application becuase that is the exact gap between the teeth. Gotta love the accuracy of these machines |
#11
| Originally when I designed it, I actually thought **** yeh this is low. But it actually works fantastic and is quite a comfortable height, I have a standard rolling chair, and the lcd sits at the right height. The jobs are actually quite easy to setup at this height. Its wide enough that I can even sit a standard house door onto the base frame. I had to build the unit this low as storage is a major concern in my shed, at this height it can roll under my main work bench when not in use, Major plus, but ive used it every day since construction, so havent needed to store it away yet. Where abouts in aussie are you |
#12
| Simso I am in Geelong Vic. This thread shows my router build so far. I've done a bit more and must take some more pics and post. Another Aussie homebuilt router Last edited by Greolt; 01-26-2007 at 07:55 PM. Reason: Typo |
| New home made MadVac CNC router | oneyaker | DIY-CNC Router Table Machines | 20 | 02-05-2011 06:37 AM |
| 5-Axis Home made Router | paulried | Commercial CNC Wood Routers | 12 | 04-23-2010 08:03 PM |
| My simple,low cost,home made CNC router | 94vette | DIY-CNC Router Table Machines | 23 | 06-17-2007 01:37 PM |
| Home made CNC mill (and some products made by it) | gcamlibel | DIY-CNC Router Table Machines | 23 | 04-05-2004 06:54 PM |
| home made CNC wire cutter and router | geesville | DIY-CNC Router Table Machines | 5 | 02-05-2004 09:24 PM |
