Old 01-25-2007, 05:59 PM
Rance's Avatar
Rance is on a distinguished road
Using Delrin bearings
I have a need to use Delrin(or similar) as bearings on drill rod or some kind of rod. I am looking for the cheapest rod I can find that is compatible with Delrin. As an example, I would guess that black gas pipe would NOT be compatible with using Delrin due to the non-slick nature of the pipe. Either solid or hollow would work, however hollow would be better. So can someone tell me what options ARE compatible with Delrin type bearings? Thanks.
Rance
Old 01-25-2007, 07:16 PM
Den-Den is on a distinguished road
If you live near any oil-fields, try to get some used Polished Rod or Polished Rod Liners. This is the top rod in a sucker rod pumping system, often heavy chrome or spray metal finish. Available in 1-1/4", 1-1/2" or 1-3/4" dia. if you can find it. The liners would be better, they are hollow. Sometimes one will be damaged and thrown away but you can still get several feet of good material from it.
Old 01-29-2007, 07:59 AM
vger's Avatar
vger is on a distinguished road
Sucker rod
Great idea. I did some work at a place that makes those. Lots of centerless grinders working away in there. Should be great material for rails.
Delrin Linear Bearings lemoneasy Linear and Rotary Motion 6 08-22-2006 07:38 PM
skate bearings versus linear bearings paul langwade Linear and Rotary Motion 7 05-29-2006 11:06 AM
Double Bearings Or Quad Bearings? ballscrewed Mechanical Calculations/Engineering Design 5 04-18-2006 01:33 PM
Bearings (Radial Ball Bearings) The Bearing Man CNCzone Club House 0 12-18-2005 01:10 PM
