ok, I've been lurking(reading) for months now and thought it time to post. I'm probably a little nutz, but I'm buildling a large(4x8x1.5) 5 axis cnc router for milling wood and foam molds mostly. Most of the machine will be welded steel and some aluminum. I'm going to use servos. The gantry will be heavy(150lbs maybe because of the large z axis). Will two 850/oz on the x, a single on the y and single on the z should be enough power? I will probably put a counterweight or spring on the z to help with the weight. This machine is fairly large, hence the heavy gantry. I don't need lightning speed, but don't want a total slug either. I'm going to use rack and pinions. With the RPM the servos run at(approz 4000rpm), I think it wise to build transmissions to slow them down. Maybe 5:1 so I can get 800rpm to the 1 inch pinion. That should run me about 2500 IPM of travel at full throttle right? Those calculations sound right? 800rpm x 3.14(circumference of 1 inch pinion)= 2512 inch per minute. Thats fast for such a heavy gantry I guess. Maybe gear down to 8 or 10 to 1 and get closer to 1000 or 1500ipm? Sound like a good plan? slower/faster? bigger servos? ideas? If I build transmissions(don't know where to buy decent/economic tranny's), should I use timing belts or gears? The belts would be easier to change ratio later if I wanted to. any suggestions or input greatly appreciated. |
| I would suggest you go with belt and pully gearing. You can buy precision reduction gearsets but they are very expensive and you cant mix and match parts to get the ratios like you could with a belt and pully system. You'd be best to do that as you'll need to keep backlash to a minimum because gantry type five axis machines typically have difficlty holding tollerence (compared to a 3 axis machine) because of the long z axis and the presence of the 4th and 5th axis which is an opportunty for error. |
| Personally I don't see 5:1 being enough of a reduction to a 1" diameter pinion. I'm running 10:1 + a 18drive to 24 tooth drive belt final to my rack with 1" pinions and I can get 800+ IPM out of my gantry. 5:1 would be pretty hard on the servo in my machine (and my gantry is easily >then 150lbs) and I have 10" of Z.. also 5:1 would not yeald very good accuracy as the servo would not spin very fast. After building I'm pretty sure I would not be a fan of my machine if I did rack for the Z axis as when your servos fault out with out a support mechanism (ie spring or something) your tool would fall easier with rack then with say ball screw drive due to gravity.. I got my 10:1 thompson gear drive off a guy on ebay for 70-80 bucks as I recall. he had others listed that didn't match what I needed but after a few emails he had exactly what I needed.. Be sure you get the right input shaft size for what you need. For my trans the input coupler/gear would be around 200.00 new from thompson if it were not right to begin with. Belt reduction from those ratios (ie 10:1 or more) would be a pain to maintain compaired to a planetary if you can find one at the right price. I would have easily spent more then 80 bucks on belts bearings and pullies to do it that way.. Heck I spent about that much on the 2 pullies and belt that made the final drive as it's now built.. b. b. |
| I've also gone the planetary route, I don't have them running yet but they are sure alot more compact than the belt reduction's I'd planned. Also, plan for twice as much reduction as you need, reason being is you can always go to a larger gear [twice as large] as I can garrentee that @ 850oz-in you'll exceed the rating of a 1" pinion. You'd be better off w/ a 10-1 reduction and a 2" pinion. Even this might not be large enough. Bostongear.com has some great spec's for these issues. Just look under their 'open gearing' heading. I'd recommend a 12DP or less gearing solution, also stick to the 20deg, not the 14.5 Also as wcarrothers1 say's plan for a ball screw on the Z axis, the rack/pinio idea works great for the x/y axis however. Also plan to press the pinion into the rack, w/ a 850 oz-in servo w/ a 10-1 reduction a 12DP rack, w/ a 2" pinion you'll get 194lb's force [ the pinion trying to push itself out of the rack] I'd recommend a couple gas shock's to overcome that, 150lbs each @ a min. HTH Jerry [another large mill builder]
__________________ JerryFlyGuy The more I know... the more I realize I don't (Note: The opinions expressed in this post are my own and are not necessarily those of CNCzone and its management) Last edited by JerryFlyGuy; 01-22-2007 at 09:54 AM. Reason: speeling |
| I'm runnign 1100oz servos through my 10:1 then I just got 14.5deg rack./pinions from Mcmaster. They seem to work well so far but agree the 20deg's are better. My rack/pinoins are hard mounted (ie no gas shock or spring) holding them in to or against the rack. Any inconsistancy is taken up by the flex of the 1/2" shaft that sticks ~1" from the carrier bearings from the side of my gantry. Although my rails and rack are pretty much dead on streight so I don' treallly see a need making the shaft's able to spring although if a piece of something gets gbetween the gear teeth and rack then maybe that would be a reason.. Rack drive is cool for some things though compaired to screw.. for example I like being able to manually move my gantry with the power off or rather with out having to power up my system which is something I can 't really do with Y or Z power off. b. |
| Ya, I thought about making mine solid but liked the ability to adjust for wear as it moves as well as adjust for any slight inconsistancy's in the rack. I'd be a bit worried about the shaft bending. In your case, assuming it's a 2" pinion, the force is only 17.8 lb's of drive out force, which is peanuts for a 1/2" shaft overhung 1" Now, I have a confession to make, I transposed a decimal place on the previous calculation instead of 194lb's it will be 19.4 lb's. Sorry about that. The end result is you could do it either way, your going to have more backlash issues with a solid mounted system over a floating one, but that all depends on your resolution requirments. One other nice thing about having a floating connection as wcarrothers1 has said, you can move which-ever axis you want manually. I'm not sure if this is a good or bad idea, as afterwards you don't have a resolved position, but it might be usefull in some case's. W/ a floating connection, just use a air cylinder instead of a gas shock. This could be controled by a solinoid/relay and controled right from your console if need be. Lots of possibilities. Jerry
__________________ JerryFlyGuy The more I know... the more I realize I don't (Note: The opinions expressed in this post are my own and are not necessarily those of CNCzone and its management) |
| thanks guys. I actually wasn't planning on using the rack and pinion for the z for exactly the reasons you mentioned. Only for the x,y. The one inch pinion idea was just thrown in there. Probably a good idea to go with a little larger pinion. I was thinking about it last night after I posted, and after reading your input here, I am going to take the advice and go with much more reduction. Bigger servos too if I can find them for a decent price. |
| I just eyeballed a lot of the stuff with my build.. came out pretty good. I did the 1" pinion because I didn't want the ratio to go back the otherway. Did the ball screw drive on Y because I didn't want to have to hang another motor (ie more weight) out on the gantry which was already getting heavy. (my 1100oz's are 12+ lbs each) So that was another reason I didn't do rack on Y becides the trans also can double the weight of the motor..hehe Although I would love to be rack in order to manualy move the motor power off. When I say manually move the motor I'm saying move the gantry out of the way for loading or unloading or something like that. No other reason to have manual movement. b. |
| Onepimpinsummer Do you have your 4th and 5th axis designed yet. If not I have leads for you on that as well. I have run a Digitial Tool rack and pinion machine that was set up for dual z axis all running racks and never have had a problem with either the rack or the heads not staying up when not powered. Now with your setup and the extra weight that will likely be a problem for you. My machine uses BishopWisecarver dual vee rails and the pinion is held captive into the rack by the rail system. Kinda need and again, never a problem with that either. Mike
__________________ No greater love can a man have than this, that he give his life for a friend. |
#10
| Mike got any pictures? I've been tossing around several idea's for building my own 4/5 head. Are how are you ensuring there is no backlash in the rack interface on the ring gear? Jerry [ I love to see how other people do things, prompts idea's of my own ]
#11
| If you are referring to a horizontal rotary axis (like a lathe) then I'd be interested too. Thanks. |
#12
| Well guys on the a axis that lays along the x I designed it and had a friend with a machine shop build it. It is a simple transmission based on timing belts and gears. The problem was when I finally got it working there was not enough holding torque and my part would twist out of the way when the cutter made contact. Part of this was a design error and part was the simple fact I designed the 4th axis to save on high dollar wood, which took center of mass considerably off to one side. The b/c head combination can be found from a couple of suppliers. One is Donny from Whiteriver who makes them like Rab made his for his 5 axis using the sat drives. He can provide some pretty heafty motors for the two heads as well. The other is Colin Doughty who lives in New Zealand and has designed a nice system where you can buy one head at a time if that is all you need. You can find both sites here by searching for 5 axis and looking for the name hodarthestrange (Donny) or searching for a link for Colin. If you can't find it post back and I'll try to find them for you. Mike
| A 5-axis CNC machine including a rotary axis | synthetiklone | CNC Wood Router Project Log | 9 | 08-17-2007 10:11 AM |
| 4 axis controller for 3 axis machine? | tybrenis | CNCzone Club House | 8 | 01-19-2007 10:12 PM |
| Gearing down... | snooper | Mechanical Calculations/Engineering Design | 9 | 08-03-2006 12:26 AM |
| Need help on Gearing | CAM_MAN | DIY-CNC Router Table Machines | 8 | 04-05-2006 01:23 PM |
| X-axis power feed w/o CNC | dlenox | General Electronics Discussion | 9 | 05-19-2004 09:07 AM |
