Old 01-21-2007, 09:16 PM
jdwoods's Avatar
jdwoods is on a distinguished road
Threaded Rod Question
Being a newbie, I don't quite understand how the machine knows where it is. Depending on which threaded rod used, different pitch = different speeds correct? The unit I plan on building calls for 1/2 - 10 Threaded rod, I want to use 1/2 - 10 Acme rod. I know that they are about the same, but I still would like to understand how it would work. Can some one educate me on this.
Life is tough; it's tougher when your stupid - John Wayne
Old 01-21-2007, 10:05 PM
ger21's Avatar
You tell the control software how many steps it needs to send to move the machine one inch. this usually equals 200 steps per rev(stepper) times number of turns per inch (leadscrews) times microstepping amount (8 for 1/8, 10 for 1/10...)
ACME Threaded Rod JohnG DIY-CNC Router Table Machines 4 05-19-2006 02:32 PM
Threaded rod. Max-DK DIY-CNC Router Table Machines 17 03-30-2006 12:28 PM
Question obout acme threaded rod (lead screws) Hack Mechanical Calculations/Engineering Design 1 04-02-2005 01:12 PM
What Acme threaded rod to get? CNC Darren DIY-CNC Router Table Machines 7 09-29-2004 07:14 AM
