Old 02-21-2004, 02:51 AM
georgebarr is on a distinguished road
Acme Tap
I have an acme lead screw as described below:
Precision Acme Lead Screw 10 Turns/Inch, 3/8" Dia, 1 Start,
6'L, Rh Thread
I believe it measures 3/8-10. I can seem to find a tap for this screw so I can make my own acme nuts out of delrin material. Does anyone know where I can find this tap? Also, is it correct that the tap size is 3/8-10 from the description above?
Thanks,
Old 02-21-2004, 03:08 AM
ballendo is on a distinguished road
Re: Acme Tap
Hello,
Travers tool wil have this, as well as most other taps, in stock. And a t a really decent price, IMO.
http://www.travers.com
Ballendo
6'L, Rh Thread
Thanks,
Old 02-21-2004, 04:27 AM
ballendo,
All I saw at that web site are 1-3/8-10 taps. But, I need 3/8"-10 taps.
Thanks anyway,
Old 02-21-2004, 04:58 AM
John S. is on a distinguished road
George,
May not be a great help as it's n the Uk but Tracy tools have these on stock.
http://www.tracytools.com/td-acme.htm
John S.
Old 02-21-2004, 09:24 AM
foamcutter is on a distinguished road
Why not make your own tap? Do a search on this site and there are instructions for doing this. I have seen it but don't remember where on this site. Ron
ezland00 is on a distinguished road
try wttool.com
Old 02-21-2004, 02:18 PM
Thanks for your help. The tracytools.com do have the 3/8"-10 acme screws. The wttool.com site took too long to load. I will try wttool.com later.
Thanks,
Old 02-21-2004, 04:24 PM
George,
Just checked the Wttool site and they only list 3/8" x 12 at $43.7500
Old 02-22-2004, 12:04 AM
NeoMoses's Avatar
NeoMoses is on a distinguished road
Have you tried www.mscdirect.com , www.use-enco.com and www.mcmaster.com ? Surely mcmaster and MSC will have them.
My name is Electric Nachos. Sorry to impose, but I am the ocean.
http://www.bryanpryor.com
Old 02-22-2004, 12:21 AM
Blackhawk is on a distinguished road
Why are the taps so expensive?
Duct Tape is like the force,
it has a light side,
it has a dark side,
and it holds the universe together.
  #11   Ban this user!
Old 02-22-2004, 02:57 AM
Hobbiest is on a distinguished road
There are different numbers for different tolerences in the taps. I believe that 1 is the closest tolerence, but don't quote me on that. Just something to keep in mind.
Stop talking about it and do it already!!!!!
Old 02-24-2004, 01:10 PM
*Registered User*
twombo is on a distinguished road
ACME taps are kinda busy in their design. The ones I have used cut in two steps: A roughing cut with the nose of the tap and a a finish cut on the end closest to the tap holder.
The amount of material to be removed has a great deal to do with the tapping force required, so they usually cut in two steps.
Kinda like the difference in cutting a 70 percent engagement tapped hole and a 90 percent thread.
Therein lies the difference in price.
Tap Drill Calculator Freeware Rekd Product Announcements & Manufacturer News 35 11-15-2011 04:37 PM
Tapping Palafox G-Code Programing 17 03-03-2007 12:42 PM
What size of drill bit can be used for 1/2-10 acme tap? starCNC DIY-CNC Router Table Machines 11 04-29-2004 05:36 PM
what acme tap do I need for the Enco ACME rod? AJ_Mac2001 DIY-CNC Router Table Machines 15 03-08-2004 07:24 AM
Homemade Acme Tap? Verboten DIY-CNC Router Table Machines 8 07-19-2003 11:04 PM
