Old 02-20-2004, 05:53 PM
ninewgt is on a distinguished road
PICS - BOAT HULL CUT WITH CNC
Guys------- MORE PICS BELOW
I finally got around to cutting the full scale boat hull... It will actually be used for building a production mold - Its the master plug... anyway.....
Im cutting as I type. I started at 1:00 PM today and have 3 pieces cut. Pieces are 8' long, 4" thick. Below is a picture of the 3 stacked up -so its 12" tall (deep) and 8' long- a little longer if you measure the true curve perimeter. not yet glued together. I wont glue until all parts are done. The bottom is cutting now. What you are looking at is 1/4 of the hull cut from 8 pound density foam.
The finished hull is 15'11" long, and 5'-10" wide.
Parts were cut on the Cad Cut machine.
Machine is run with Ability Systems Indexer and G-Code Controller software with Gecko 201's
Stepper Motors
Programed in Visual Mill 5.0
Part file designed in Rhino and imported into Visual Mill
Each part took about 1 hour and ten minutes to cut as you see below cutting at 200 inches per minute with a 1/2" Flat End mill .
Ill get the rest cut tomorrow and sunday and post the finished hull Monday most likely but thoght youd like to see !
Pardon the low res picture
You can see a rendering of the hull at www.inshorepowerboats.com
Name:	boat hull.jpg‎
Persistance and patience are the key to CNC
Old 02-20-2004, 05:58 PM
Another pic of the parts being cut - you can see where I already removed 2 of them as 3rd was cutting
Name:	cut hull1.jpg‎
Old 02-20-2004, 06:35 PM
High Seas's Avatar
Gold Member
High Seas is on a distinguished road
Nice JOB! Did you purchase the foam as a blank - or pour it? I am looking for a good source in the SE (FL area) - got some neat samples from Freeman -- could be a contender. If you don't mind I'd like to hear your sources/opinions of materials for your project. Thanks.
Jim
Experience is the BEST Teacher. Is that why it usually arrives in a shower of sparks, flash of light, loud bang, a cloud of smoke, AND -- a BILL to pay? You usually get it -- just after you need it.
Old 02-20-2004, 06:37 PM
Mr.Chips's Avatar
Gold Member
Mr.Chips is on a distinguished road
That's really NEAT.
Will the foam be fiberglassed, for a durable finish?
What's the work area size of your machine?
Is the construction of your machine in this forum?
Hager
Old 02-20-2004, 06:59 PM
barkster is on a distinguished road
I would love to hear where/how you got the foam too. I'm looking to make some plugs for some R/C Jets. Thanks for the post, looks great
Old 02-20-2004, 08:33 PM
balsaman's Avatar
balsaman is on a distinguished road
Cool.
Serious dust I imagine eh?
E
I wish it wouldn't crash.
Old 02-20-2004, 08:48 PM
HuFlungDung's Avatar
Moderator
Interesting, Ninewgt. Its good to see that you are making some dust
Old 02-20-2004, 09:29 PM
I purchase the foam from the same supplier that we purchase high density foam that we build our transoms with. You can purchase it in 4X8 sheets up to 10" thick. The sheets I used were 4.25" thick - not cheap stuff though - about 400 per sheet. If you need small pieces for RC stuff let me know what sizes... I have pallets of scrap foam Im looking to get rid of -
Yes it will be fiberglassed with a thin layer of cloth (4 oz) and then sprayed with a sandable primer thats basically a gel coat with added fillers for easier sanding....... then we will build a mold on it after sanding / buffing / waxing........
The machine work area is 50" X 98" X 10" max.......
Yes I used a machine on this forum - the Cad Cut CNC - Im the one that designed it. There is a forum on CNC Zone pertaining to builders of the machine or see the website at :
http://www.inshorepowerboats.com/cnc.../CNCROUTER.htm
Yes guys - Im talking a PILE of dust like you cant imagine - barrels of it - no joking ! But the speed in which I was able to cut it was fantastic - 27 Square feet (actual surface area I cut today) which is the total of the 4 parts in about 6 1/2 hours....... not bad at all, and it cut fantastic - I am very pleased with the results. Ill get the entire hull finished this weekend....
Old 02-22-2004, 07:38 AM
I got the front half finished Saturday.........
Here are the pieces stacked up - Looks like a boat now..... Just gotta cut the rear today !
I am a happy camper guys...... This machine did all the above in a days work... what would take me hundreds and hundreds of hours to do the way I used to do it........ and it did a perfect job.
Name:	front half.jpg‎
Old 02-22-2004, 08:54 AM
Bloy2004's Avatar
Fumbling Machinist
Bloy2004 is on a distinguished road
Fantastic! I really like your machine design and as I progress toward building a router and, depending on just what my needs will require in a machine, your's will be the basis.
  #11   Ban this user!
Old 02-22-2004, 01:15 PM
Blackhawk is on a distinguished road
I am going to cut out an RC boat with mine when it is finished, what type of bit did you use? I was thinking that a normal router bit would clog up with foam.
Duct Tape is like the force,
it has a light side,
it has a dark side,
and it holds the universe together.
  #12   Ban this user!
Old 02-22-2004, 03:20 PM
To cut wood, or foam get a flat end mill, which is a spiral cutting bit meant for maching metal. Make sure you get 'center cutting' bits. I use up cut bits for foam and down cut bits for clean edge cuts in hardwoods
Pics of my RF45 clone cnc conversion with flood coolant CNCPlastic Knee Vertical Mills 9 01-26-2005 02:02 PM
CNC Gantry Painter Build Pics - Night 1 vacpress Printing, Scanners, Vinyl cutting and Plotters 29 04-09-2004 04:43 PM
Cut A Boat Hull Today ninewgt DIY-CNC Router Table Machines 1 03-26-2004 02:56 PM
Machine Tool Camp 4'x8' VS Cad Cut CNC 4'x8' Router Trimix DIY-CNC Router Table Machines 6 12-18-2003 01:49 PM
how do i get my cnc to cut my acad dwg? ljoe1969 Autodesk Software (Autocad, Inventor etc) 6 11-05-2003 10:05 AM
