| Isn't 35mm around an 1.5"? They make 80/20 plenty big enough for that size. The 3" wide should do fine. However, you're going to pay for it. Why can't you use aluminum channel to support the bearings? 80/20 is over kill in my opinion. Take a look at Shopbottools.com table. They even have plans for it. This is what I am using only aluminum. Up to you though. I believe the 80/20 that is 3x6 is around $2.50 an INCH so times that by 60 and you are looking at $150.00 just for one rail. |
| I called 80/20 and they said they did not make anything big enough to have a t slotted part to be 35 mm. I will take a look at the website you gave me. Thanks a lot...keep em comming! P.S. can you send me a link to shopbottools page where the aluminum chanels are? I couldn't find them... Last edited by wakeboard; 02-19-2004 at 07:01 PM. |
| For a long time, one of the leaders in extrusions for machine building has been ITEM, they have been taken over by Parker at http://www.parker.com/ead/cm1.asp?cmid=809 Al |
| My 1st Router - PEU | PEU | CNC Wood Router Project Log | 221 | 03-06-2012 05:36 AM |
| 80/20 Specs - Lathe Construction | Deviant | 80/20, TSLOTS and other Aluminum Framing Systems | 13 | 04-05-2005 10:27 PM |
| question of ignorance- Can you do your own extrusions? | july_favre | Bending, Forging,Extrusion... | 5 | 09-17-2004 10:28 PM |
| T slot extrusions | tsalaf | DIY-CNC Router Table Machines | 5 | 09-18-2003 10:14 PM |
| Aluminum Extrusions | Woodie1 | DIY-CNC Router Table Machines | 2 | 09-13-2003 12:38 PM |
