Old 01-12-2007, 02:47 AM
Smackre is on a distinguished road
Dro on a rotary axis.
I have a non cnc machine i would like to add 2 rotary axis to. Right now the machine is a 3 axis machine with a dro on each axis. But i have no idea how to do a DRO on a rotary axis. This is for a bowling ball drilling machine. I can get exact positioning for drilling the holes but getting the right angle is imposable.
if anyone has any idea how to do a dro on a rotary axis please give me some info. Also if this is posted in the wrong section please move it. i had no idea which section it should go into.
Old 01-12-2007, 08:10 PM
NC Cams is on a distinguished road
You an use a Heidenhain ROD encoder to make a rotary encoder driven DRO - pricey but accurate to arc seconds.
You can also use some Red Lion counters and pulse generators to make a less expensive DRO. Depending on the gearing and count output, you should be able to get to 0.1 or 0.01 degree relatively inexpensively.
Old 01-12-2007, 11:20 PM
Al_The_Man's Avatar
Here is a link for free DRO s/w using a PC parallel port, you should be able to use any single ended encoder, and it also has a scaler for 360° to use on a rotary indexer http://www.lindsayengraving.com/othe...rests/dro.html
Old 01-15-2007, 09:20 AM
jcc3inc is on a distinguished road
Rotary encoder
Sir,
I like the Red Lion readout along with an encoder from Encoder Products. I use both on my test bed machine. E#mail me for more info.
jccinc-at-owc-dot-net
Regards,
Jack C.
Old 01-15-2007, 05:16 PM
wcarrothers1 is on a distinguished road
Call me crazy but how about 2 of these things
http://www.rockler.com/gallery.cfm?O...Select=Details
I have one and they are cool. Basicly works the same way as the digital calipers only it's rotary
b.
Old 01-16-2007, 07:33 AM
Rance's Avatar
Rance is on a distinguished road
b,
I actually just bought one of these AND I LOVE IT, but only for my table saw. The lag time is too great to use for a DRO. I did use it to check the alignment of my rails and it was dead on. A very good tool, none the less.
Old 01-16-2007, 08:23 AM
Figured he was only asking about a digital read out ie not using the output to a program or computer. Or in other words manualy setting up something before drilling..
b.
Old 01-16-2007, 08:45 AM
Rance's Avatar
b.
Well, after pondering a little I think it could have a place on a mill. I'd say go for it.
