Old 02-14-2004, 12:02 PM
freezer is on a distinguished road
My work in progress, suggestions welcome!
Well, I have most of the wood working done, waiting on the drill rod and bearings to show up and still looking for some steppers to run this thing… But anyway, here is what I have so far…
All the joints are rabbited, glued and nailed. Chose the JohnDeere color skeem...
I welcome any suggestions... It is easer to fix it now than after I get it all done!
Old 02-14-2004, 01:06 PM
Hobbiest is on a distinguished road
looks like a pretty darn good start!
Stop talking about it and do it already!!!!!
Old 02-14-2004, 10:37 PM
Mr.Chips's Avatar
Gold Member
Mr.Chips is on a distinguished road
That's a pretty old John Deer, I can see the crank for starting it sticking out of the middle. HeHe ;=)
What size drill rod are you using and what kind of bearings.
Good looking machine, keep the photos comming.
Hager
Old 02-15-2004, 09:54 AM
I orderd 1" drill rod for the x and y axis and 3/4 for the z. The bearings are http://www.use-enco.com/CGI/INSRIT?PMAKA=325-7583 and http://www.use-enco.com/CGI/INSRIT?PMAKA=325-7589. I just have to take extra care in mounting the bearings so they don't bind!
Old 02-15-2004, 02:58 PM
Mr.Chips's Avatar
Gold Member
With every axis having two shafts, alignment in all directions is critical and not easy to do.
That's one nice thing about Crankey's shaft mounts, there's pleanty of adjustment to get the job done.
I'v started two times to write a procedure for bearing setup and alignment, not happy with either. Want to make it simpler but yet accurate.
Hager
Old 02-15-2004, 08:11 PM
Chips, I had thought of that. Luckley, the bearings are inexpensive and if they prove to be too difficult to adjust, i can revert to the rollerblade bearing design... I beleave that the 1" drill rod will be stiffer than the gas pipe and smoother as well... although, the drill rod is more expensive than gas pipe but greatly cheaper than linear rails!
i can't work out the logic for this type of program, any suggestions? Darc G-Code Programing 12 02-06-2005 08:08 PM
Need suggestions on components 5 axis control system? pab Mach Software (ArtSoft software) 0 01-19-2005 04:34 PM
Work Holding Methods InventIt DIY-CNC Router Table Machines 13 09-14-2004 03:13 AM
What is 2.5 d work Patrick2by4 DIY-CNC Router Table Machines 9 07-05-2004 11:04 AM
First router suggestions. Hobbiest DIY-CNC Router Table Machines 10 06-07-2004 09:07 PM
