Old 01-02-2007, 11:12 PM
woodworker2 is on a distinguished road
Help with router
Hi, I am about to purchase a cnc router, and I will be using it more for drilling through wood and aluminum than cutting. I have a hitachi variable speed router. It takes a standard 1/2" diameter bit and has a 1/4" collet as well. How do I get typical drill bits mounted in the router? I use 15/64", 3/16",
5/16" and letter Q drill bits, along with freud hole fostner bits, typically 1/2" and 3/4" which usually have a 3/8" diam. shaft.
Old 01-03-2007, 12:27 AM
Lionclaw's Avatar
Lionclaw is on a distinguished road
I use a 1/8" endmill for most of my cutting and hole drilling. Someone else will probably have a better answer for you though with regard to drill bits. With a small endmill however you should be able to cut any hole with a diameter equal to or larger than the endmill with a G2 instruction. I believe Enco sells some bits that are both drill bits and end mills as well.
Andy
CNC Kits - http://www.comptonsoft.com/cncweb/
Old 01-03-2007, 12:32 AM
joecnc2006's Avatar
www.joescnc.com
joecnc2006 is on a distinguished road
If you want to use different size bits then you need to get collet adapters, ehich will havd I.D. what you want and an O.D. of 1/2" I got one for the hitachi router to use 1/6" bits, i will have to remember where i got it from but there are several places.
Old 01-03-2007, 04:46 AM
Jayson is on a distinguished road
Hi woodworker2,
As joe2000che says, you will need collets that fit your drill bits. If you have a lathe you could make them or get someone to make them for you. Its not all that hard to do it just takes a bit of setting up to get them correct. I use a cheap router on my machine and have made around 5 different sized collets for it. This is the best solution IMHO.
Regards,
Jayson
Quick... catch all the smoke so I can stuff it back in.
Old 01-03-2007, 07:14 AM
ger21's Avatar
You should NOT use drill bits in a router. They're not designed to spin at such high speeds and using them at those speeds is dangerous. Also, at 8000 rpm, a 3/4 forstner bit will get so hot it will be useless in about 30 seconds or less.
Old 01-03-2007, 07:57 AM
wcarrothers1 is on a distinguished road
I'm with Ger..
But Porter cable routers are avaliable with 1/4 3/8 and 1/2" collets (least for my monster 3-1/4hp 1785 router)
Which is cool since that alows me to use the 3/8" shafted end mills I have in the router...
although like ger said bits that big can't spin at even the slower end of a variable speed routers range.. Becides the heat a router motor bearings are not designed to take vertical loads like that. They mostly take horizontal loads..
But anywho..
b.
