Old 01-01-2007, 05:25 PM
studysession is on a distinguished road
DIY CNC Router legs
Hi -
Been following a lot of threads on their DIY projects. So I started my own. Money is very limited and have a question about the legs for this thing to stand on.
Would it be stable enough to put a 4x4 wooden post around 3 foot tall at each corner? The table is 4 foot x 5 foot.
Thanks!@
Please check out my CNC blog
http://cncinside.com
Old 01-01-2007, 06:25 PM
Lionclaw's Avatar
Lionclaw is on a distinguished road
You would definitely need some cross bracing if you did that. It would probably be very wobbly with just 4 posts and no bracing.
Andy
CNC Kits - http://www.comptonsoft.com/cncweb/
Old 01-01-2007, 06:30 PM
Thanks -
I would do cross bracing - Just trying to figure out a cheap but stable solution.
Old 01-01-2007, 08:40 PM
*Registered User*
DayneInfo is on a distinguished road
Here is a picture of one on 4x4's , It is Joe's router http://www.cnczone.com/forums/attach...5&d=1136163253
Old 01-01-2007, 09:00 PM
Madclicker is on a distinguished road
Here's a bigger one on 4.5 X 3.5 legs...before and after added bracing. I cut a *lot* of wood before adding the skirts with no problems.
http://www.cnczone.com/forums/showpo...&postcount=119
Steve
DO SOMETHING, EVEN IF IT'S WRONG!
Old 01-01-2007, 09:04 PM
Is that like 3 2x4's put together for one leg?
Old 01-01-2007, 09:09 PM
Yep, that's all I did.
Steve
Old 01-01-2007, 09:11 PM
Cool - how sturdy is that?
Old 01-01-2007, 09:14 PM
Extremely sturdy! I climb on it all the time. Also, after adding the side skirts there is no wiggle any which way...except for the movement in the cast iron castors.
Steve
Old 01-01-2007, 09:17 PM
Thanks - That's looks great. I like the side skirts.
I see a lot of people use wood and another thread a guy used plywood. Is that common for these kinds of routers?
  #11   Ban this user!
Old 01-01-2007, 09:31 PM
I seldom use plywood for tools. It starts warping from the minute you pull it from the rack. One exception is the router table fences I make out of baltic birch ply. The design I have, combined with the stability of baltic birch makes a good product.
Dimensional wood would be a far third in my choice of materials for tools.
I think mdf is a superior product to make jigs and tools from.
Steve
  #12   Ban this user!
Old 01-01-2007, 10:21 PM
Lionclaw's Avatar
Since MDF is so soft on the edges, I would expect crushing where the pipe rides after time.
Wouldn't this make it unsuitable for use in making tools?
Edit: NM, I just read in your build log that you used hardwood up against the pipes. Would you consider baltic birch plywood (not the veneered stuff) superior for making machines?
I'm considering switching to building my machines from the veneered birch to baltic birch. The cost would be significantly higher, but if there's a demand for it then I suppose it's worth it.
Andy
