I made my Z out of some heavy duty drawer slides, but it is just not rigid enough now that I am cuttingmaterials harder than balsa. I am also having difficultties mounting my dremel rigid enough to the Z axis. Any suggestions for an inexpensive Z slides? I searched through e-bay and found nothing really. also any suggestions for mounting a dremel more rigidly to the Z axis would be appreciated. Thanks co |
| It's just a thought, really, but what about some U-bolts? The kind you used to use when installing TV antennas on the roof... It's a U of steel, threaded at both ends. Get some that actually fit, and clamp your Dremel to your Z axis. I haven't tried this, but it seems like it should work. -- Chuck Knight |
| I am currently using plastic U clamps. The problem is, you have to clamp the Dremel pretty far from the bit, so the lever arm is pretty long. The bit can grab and move the dremel. I have some delrin, I might machine something to work. I am mostly worried about the slides, they are just not rigid enough. Any suggestions? co |
| Seems like I recall Dremmel having an adapter you could use. I'm thinking of the "router" attachment. As I recall, it threads onto the Dremmel itself. Maybe one of those jury-rigged up to a right angle plate (plastic and glue?) fastened to the zaxis? Would move the moment arm closer to the tool/bit anyway. How about figuring outthe thread on the "nose" of the dremmel and cutting/taping into a piece of plastic/mdf to make a mount out of? Or maybe the "extendo-bit" that looks like a long wigglie-pencil. Fix that to the rail and mount the main unit out of the way? You could get some of that modeling/baking clay and mold an adapter then bake it and use screws through that or the u-bolts. I'm gonna quit before these get tooo goofey sounding. Good luck! Jim
__________________ Experience is the BEST Teacher. Is that why it usually arrives in a shower of sparks, flash of light, loud bang, a cloud of smoke, AND -- a BILL to pay? You usually get it -- just after you need it. |
| How about this? http://cgi.ebay.com/ws/eBayISAPI.dll...category=11805 Just join the 2 rails together for 12" rails, although the price will probably skyrocket in the next 2 hours. Gerry
| My biggest problem is the axis itself. I want something not too bulky and very rigid. I have seen a bunch, but cant find anything when I need it of course. There used to be a seller on ebay called the manufacturist, they had some applicable stuff but I cant find them. co |
| What about hooking a motor and lead screw up to the Dremel drill press mount, and using it for the Z axis?
__________________ Stop talking about it and do it already!!!!! (Note: The opinions expressed in this post are my own and are not necessarily those of CNCzone and its management) |
| 4020 4th axis problems | little bubba | Fadal | 3 | 06-13-2005 09:08 PM |
| No Encoder Counts On X Axis. Y=OK | murphy625 | CamSoft Products | 5 | 03-08-2005 08:20 PM |
| Need suggestions on components 5 axis control system? | pab | Mach Software (ArtSoft software) | 0 | 01-19-2005 04:34 PM |
| 2 axis to 3 axis conversion | drembedded | Bridgeport and Hardinge Mills | 10 | 10-27-2004 11:32 AM |
| My Lathe project; might CNC it one day | Stevie | General Metal Working Machines | 86 | 06-21-2004 08:27 PM |
