Old 02-08-2004, 08:39 PM
Hobbiest is on a distinguished road
Centering blocks
Had the idea last night...instead of making some centering blocks out of MDF or whatever, just get the next size up pipe flange and drill and tap four holes toward the center! Steel threads hold a lot better, and its not like the things are really that expensive!
Old 02-09-2004, 11:25 AM
AJ_Mac2001 is on a distinguished road
Nice Idea!!
Would have liked to have had that brain_art a month back when I was working up 16 pcs (ply versions) with a blunt holesaw. I think the smoke is just starting to clear in my shop
Old 02-09-2004, 01:25 PM
xairflyer's Avatar
xairflyer is on a distinguished road
Does sound like a very good idea, what thickness would the wall of the flange be that you'd be tapping ?
Old 02-09-2004, 08:05 PM
I think that the flanges are 3/16". With a fine thread bolt there should be plenty of threads in the piece. It could even be backed up with a nut on either side if the ID of the flange is big enough. jam nuts on the outside would be a good idea in either case.
Stop talking about it and do it already!!!!!
Old 02-09-2004, 10:57 PM
pack rat is on a distinguished road
You could add a short nipple or a half of one and tread that . Schedule 80 will also give you more thickness. Good idea.
iko blocks seem too stiff. bgolash DIY-CNC Router Table Machines 4 03-14-2005 01:50 PM
end blocks for ball screws senor J. DIY-CNC Router Table Machines 7 02-26-2005 02:05 AM
RFQ Simple Aluminum Bearing Blocks b0gh0s Employment Opportunity 8 12-23-2004 03:57 PM
screwless vice clamp blocks JFettig Benchtop Machines 8 04-16-2004 07:03 AM
Making your own pillow blocks and Rail mounts? Zephrant DIY-CNC Router Table Machines 20 05-19-2003 06:34 PM
