Old 12-23-2006, 09:50 AM
kevincnc is on a distinguished road
Mini CNC Router progress pictures
Hi All,
I haven't posted for a while, but some of you may remember this router that I started a couple of years ago. Progress has been very slow and intermittent..too many other projects, hobbies and interests. I'm going to try to make a final push and get this thing running now.
The first picture shows the new spindle. It's a nice high frequency Perske motor originally used for a trim saw on an edgebander. Ebay is not always evil- it was $75, unused. All I had to do was cut off the shaft and make quick-change tool holders that screw on. I also changed the spring washer arrangement, and then had it re-balanced. It's rated 1.4HP, 17,030 RPM at 300Hz. Using a small Yaskawa VFD to convert 220 single phase to the required 165V 3 phase, it runs nice and smooth, and much quieter than a hand router.
Z-travel was increased to 4-1/2" by joining short rails together, and it has 4-3/4" clearance under the gantry. All the axes are complete now, using all precision ground, preloaded ballscrews and dc servos. I'd like to be able to cut soft metals with it, so ribs on the sides of the gantry bolted to an extended bottom cross piece will probably be added to stiffen it up.
The next picture shows the new enclosure made from Bosch extrusion that I picked up at a local surplus store for $2/lb. I purchased the connecting hardware and door hinges from a local Bosch distributor, which cost more than the extrusion itself. When finished, it will have 1/4" lexan doors on the top, and something like 1/4" MDF to enclose a shop-vac in the bottom to keep dust contained. The industrial PC on top came from ebay- I'll probably replace the CRT with a flat touchscreen eventually. The nice precision machinists vise was also a steal on ebay for $150. The table top will probably get a grid of tapped holes for clamping, then eventually a vacuum table can be added.
The last 3 pics just show some detail. Encoders are mounted to the servos and to the ballscrews on X and Y. Amp CPC connectors will allow me to use either set. The 2000 CPR encoders on the screws give better than .0002" resolution, so it should be able to engrave on a pinhead if I ever get the urge.
Enjoy the pictures, and I'd be happy to answer questions if anybody has them. More progress to come soon, I hope...
ID:	27745   Click image for larger version
ID:	27746   Click image for larger version
ID:	27747   Click image for larger version
Old 12-23-2006, 10:10 AM
thkoutsidthebox's Avatar
thkoutsidthebox is on a distinguished road
Very nice.
Old 12-23-2006, 10:27 AM
haciman is on a distinguished road
very good machine.
Old 12-23-2006, 10:29 AM
It looks really solid. What type of router is that, I've never seen one like it before?
Old 12-23-2006, 12:21 PM
Thanks guys. That's not a "real" router motor, just high-speed motor that makes a good router. I think it was made custom by Perske for a Torwegge edge bander laminate trimming station. It's rated at 17,030 RPM but could probably be pushed a little faster without damage.
Old 12-23-2006, 12:46 PM
Switcher's Avatar
Moderator
Switcher is on a distinguished road
Great job!
Old 12-23-2006, 05:04 PM
widgitmaster's Avatar
Gold Member
widgitmaster is on a distinguished road
That's one nice looking Router table!
Its nice to see things bolted together with socket head cap screws, it gives everything a touch of professionalism!
I also like the 8020 rack to contain the router and the PC, nice touch!
Hope it serves you well!
Eric
Old 12-23-2006, 05:53 PM
walter's Avatar
Gold Member
walter is on a distinguished road
Looks solid to me I like it!
Old 12-23-2006, 07:42 PM
2muchstuff is on a distinguished road
Looks like a winner to me.
If it's not nailed down, it's mine.
If I can pry it loose, it's not nailed down.
Old 12-23-2006, 11:16 PM
ZipSnipe is on a distinguished road
Great lookin machine. Nice find on the spindle.
