Old 02-06-2004, 03:21 PM
CNC Brute is on a distinguished road
build your own linear bearing
Anyone have a link for a build your own linear bearing using ball bearings?
I would definitely like to see if someone has imitated a Thomson shaft bearing using ball bearings and not "regular" bearings.
Old 02-06-2004, 03:51 PM
jgro's Avatar
Gold Member
jgro is on a distinguished road
Try here http://www.buildyouridea.com/ He used to have his HBLB (home brew linear bearings) for sale. Send him an email, maybe he'll sell you some.
jgro
http://jgroshoppages.blogspot.com/
Old 02-06-2004, 04:50 PM
Hobbiest is on a distinguished road
He doesn't sell them any more, not lucrative enough.
Stop talking about it and do it already!!!!!
Old 02-06-2004, 09:12 PM
jgro,
I've seen that site before, but didn't have it in my book marks. But it also brings up two question
1. Why use bearings with a flat surface on tubing style shaft instead of square bar shaft?
I'll draw up my idea for DIY Thomson linear ball bearings when I get home tonight maybe you guys can give me an idea if it would work or not.
Old 02-07-2004, 03:32 AM
CNC BRUTE,
Round shaft will allow cutting debris to stay on only a small portion of the surface compared to square tubing. As far as DIY Thompson style, all I can say is that in my own experements the bearings don't like to be fixed. They seem to need recirculating motion.
gas pipe & linear bearing dimensions relationship zoltan Linear and Rotary Motion 6 06-13-2005 03:12 PM
Linear Bearing mat’l? jakk100 Linear and Rotary Motion 19 05-18-2005 12:15 PM
a cheap linear bearing mocnc DIY-CNC Router Table Machines 8 03-26-2005 04:52 PM
Linear bearing spacing & Sizing linear rails? fyffe555 DIY-CNC Router Table Machines 3 12-07-2004 01:09 PM
What is a linear bearing ? ynneb FAQ of CNC Machine building 0 08-16-2004 09:34 PM
