Old 12-06-2006, 05:11 PM
KrashKing405 is on a distinguished road
photo copier steppers
Anyone tried salvaging steppers out of a photo copier [xerox style]?
Old 12-06-2006, 05:19 PM
Jason Marsha is on a distinguished road
They can work, you will find anywhere from 80 oz/inch to 200 oz/inch inside.
However you normally not find info about the steppers since they are manufactured for the copier company.
Jason
Old 12-06-2006, 05:38 PM
Thanks for the reply. I've been offered a couple different machines already. I'll see what I can find out on the steppers when I get into them.
Old 12-07-2006, 03:55 PM
Strip the skate bearings (608 series) as well.
Jason
Old 12-07-2006, 04:54 PM
I'll probably strip anything and everything I can from them. I've heard there is some good rods, power supply, even some aluminium to melt down.
Old 12-09-2006, 06:26 PM
2muchstuff is on a distinguished road
There was at one time a thread on copier steppers. I think it was something like "rading photocopiers for steppers".
If it's not nailed down, it's mine.
If I can pry it loose, it's not nailed down.
Old 12-09-2006, 06:36 PM
Oldmanandhistoy is on a distinguished road
Try here http://www.cnczone.com/forums/showthread.php?t=19362
John
Old 12-10-2006, 06:59 PM
My god that was alot of work. Got 3 smaller steppers, and from what I've read, 3 BIG servo motors. Kept the power supply, BUNCH of bearings, gears, belts, and misc. other hardware. Planning on using the chassis to put my finished router on, has a couple shelves to store stuff.
Old 12-10-2006, 07:45 PM
Rance's Avatar
Rance is on a distinguished road
Krash, Next time make sure you use a cordless screwdriver. It makes it a LOT easier/faster.
Old 12-10-2006, 08:10 PM
Darn screws they used were CHEAP. was stripping the heads on em with the regualr screw driver, electric one woulda been worse. I forgot to mention the nice sets of roller chains [like a bicycle chain] that I got, 2 different sizes, I also kept all the cogs/gears that went with them. Thinking of ebaying the odds and ends as "robot parts" .
  #11   Ban this user!
Old 12-14-2006, 02:53 PM
project5k's Avatar
project5k is on a distinguished road
wish i could get my hands on some old copiers like that, i could sure use the bits and pieces...
Grizzly X3, CNC Fusion Ballscrew kit, 3 500oz-in bipolar steppers, 3 203v Gecko's, Linear power supply from Hubbard CNC, Mach 3, BOBcad Pro Art V22, Rhino.
  #12   Ban this user!
Old 12-14-2006, 03:24 PM
thkoutsidthebox's Avatar
thkoutsidthebox is on a distinguished road
That thread is Post 7 above is great. Thanks Oldmanhist
