Hello all I wonder if will be useful to use a flex axis extender (I don't know the correct term in english, I mean the flexible tool used to reach difficult places with a drill) in order to have less weigth in Z-axis and through this way being able to use cheaper steppers and electronics. I have't seen this approach until now so maybe is well known but has well known drawbacks that I can't guess.. Thanks in advance and pardon again about my bad english. /S |
| Sounds like a goiod idea but, I the size of the steppers is to provide a movment in relation to the cutting force, not the weight of the z. The more robust (weight) a machine the more accurate.
__________________ Thank You, Paul G Site Owner-Webmaster- Administrator www.rfqwork.com www.cnczone.com www.welderzone.com |
| I was thinking about a flex shaft on a router. Stick the router in a ventelated, but pretty soundproof box, and you don't get annoid. The tolerences in the flex shaft may not be too good though.
__________________ Stop talking about it and do it already!!!!! (Note: The opinions expressed in this post are my own and are not necessarily those of CNCzone and its management) |
| Well, I always thougth about the Z assembly only working to raise and down the tool, and X&Y working to move the piece, or the machine relative to the piece. Probaly my mistake when refering to 'the steppers' when wanting to say 'the Z-Axis stepper'. /U |
| CNC admin is absolutly right. If you have proper slides, the assemly should still be reletively easy to move, regardless of weight (horizontal at least...vertical does have to account for weight, but keep in mind the mechanical advantage of different screw pitches). I like the idea of a flex shaft for ease of mounting, and possible sound deadening.
| 4020 4th axis problems | little bubba | Fadal | 3 | 06-13-2005 09:08 PM |
| No Encoder Counts On X Axis. Y=OK | murphy625 | CamSoft Products | 5 | 03-08-2005 08:20 PM |
| 2 axis to 3 axis conversion | drembedded | Bridgeport and Hardinge Mills | 10 | 10-27-2004 11:32 AM |
| My Lathe project; might CNC it one day | Stevie | General Metal Working Machines | 86 | 06-21-2004 08:27 PM |
| 2.5-Axis vs 3-Axis | JamesBond | General Metal Working Machines | 6 | 07-26-2003 07:09 PM |
