Old 12-03-2006, 07:14 PM
blau_schuh is on a distinguished road
Is 0.650" too large a pitch for a diy router?
There a couple on ebay right now...
Old 12-03-2006, 08:24 PM
Oldmanandhistoy is on a distinguished road
Ball screw or lead screw?
Need to cut to tight tolerances?
More info needed
John
Old 12-03-2006, 08:35 PM
More info needed
John
wood for the most part since this is my first router, maybe some aluminum.
not talking crazy tolerances...
Old 12-03-2006, 08:36 PM
This is a ballscrew
Old 12-03-2006, 08:42 PM
ger21's Avatar
Depends on a lot of things, but should work fine if you have enough power to spin it. You could always gear it down with belts and pulleys.
Old 12-03-2006, 08:50 PM
I have some 250 oz-in servo motors.
Old 12-04-2006, 04:03 AM
project5k's Avatar
project5k is on a distinguished road
what rpm are thoes servo motors good up to?
Grizzly X3, CNC Fusion Ballscrew kit, 3 500oz-in bipolar steppers, 3 203v Gecko's, Linear power supply from Hubbard CNC, Mach 3, BOBcad Pro Art V22, Rhino.
Old 12-04-2006, 10:47 AM
rated speed: 3500 rpm
Old 12-04-2006, 11:05 AM
ger21's Avatar
With servos, you shouldn't have any problems. Just use gear reduction with pulleys and belts to achieve your desired rapid speed.
Old 12-04-2006, 12:40 PM
project5k's Avatar
well i dont know what the resolution on a servo is, but if you gear it down 10:1 then that would spin the screw at something like 350rpm, and that would be about 227 ipm rapid... and then you could take the # of "steps" (for lack of not knowing the right term) and multiply it 10 and then take that # and devide your .65 by it, and that would give you the best resolution that you should be able to do.... so just for example, if the motor had 200 steps per revolution then your max res would be .000325 inches... thats very good in my book...
