Old 11-26-2006, 08:48 PM
northernmach is on a distinguished road
Transformer question need help!
I am trying to use this tranformer at the following link. http://www.alliedelec.com/Images/Pro...TIC/F-401U.pdf
When I conect to the primary and then test at the secondary wires shouldn't it be in vdc? I still show vac. I am very confused and don't want to go to the capacitor with it. I lost the instructions that were for one of hobbycnc's boards.
Thanks,
Chad
Old 11-26-2006, 08:55 PM
erase42 is on a distinguished road
no the output will always be AC when coming thru a transformer, the device that will convert it to DC for you is a rectifier. Usually a full wave bridge rectifier is what is used. It is made up of 4 diodes but you can usually find in the form of one unit with 4 leads. The AC goes in to two of the leads and DC magically flies out the other two leads. Do
Old 11-26-2006, 08:56 PM
oops. Do a google search for bridge rectifier and im sure you will find the info you need.
Ed
Old 11-26-2006, 08:59 PM
thanks for the help erase! That will definately clear things up for me.
Old 11-26-2006, 09:18 PM
Madclicker is on a distinguished road
Just spitting hairs, but the output of the bridge is also AC, but with a DC content. The cap stores much of the AC peak voltage and supplies a relatively clean DC.
Steve
DO SOMETHING, EVEN IF IT'S WRONG!
Old 11-26-2006, 09:37 PM
this is true, but when you really back up and look at it, does the transformer even exsist?
Old 11-26-2006, 09:58 PM
Yes.
Steve
Old 11-26-2006, 10:04 PM
Al_The_Man's Avatar
Alternating means it changes polarity, the bridge output does not, it is pulsating DC, 120hz ripple from peak to zero.
Old 11-26-2006, 10:10 PM
wasnt sure if the pulses could be considered alternating, thought not, but life is too short to go around standing up for things you are merely pretty sure of. the original gentleman got his answer so he could move on tho, hopefully thats the ultimate purpose of these forums.
Old 11-26-2006, 10:41 PM
Alternating just means it changes from one low value to another higher value. The current alternates from zero at the bottom to whatever the peak is in the case of the output of a rectifier bridge. Alternating signals are all characterized also by their DC content. If this were not true, the measured AC value of the output of the bridge would be 0? But, it never is.
Steve
Old 11-26-2006, 10:47 PM
Al_The_Man's Avatar
The output of the transformer alternates polarity 60 times a sec, the bridge rectifier 'Steers' this and produces a pulsating DC. i.e. the Bridge output does not 'Alternate' polarity, as the transformer output (and Primary supply) does.
If it did not alternate, there would be no need for the Bridge.
  #12   Ban this user!
Old 11-26-2006, 10:55 PM
The current AND the the voltage alternate. ALTERNATING CURRENT. NOT ALTERNATING POLARITY. Alternating as in "changing"!
Steve
