Old 01-25-2004, 12:50 PM
sixpence is on a distinguished road
Where to purchase lead screws?
Hello all
Please help! I have just received a quote on ball screws from my local SKF dealer. 8mm dia x 910mm 2.5 lead = rough conversion to $ 527.00. The prices I've seen on ebay and this site makes me think this is too high. Is it?
The larger diam 12mm X910mm 5 lead was slightly cheaper. How come? Rep is not very forthcoming with info.
Solid guide shafts 16mm x 910 = $25.00 which seems very reasonable?
These prices exclude shipping. Nobody locally seems to stock ball or lead screws so I might as well order them myself off the net.
Where do I buy?
Old 01-25-2004, 01:16 PM
ezland00 is on a distinguished road
check out use-enco.com
Old 01-25-2004, 01:18 PM
HuFlungDung's Avatar
Moderator
New precision ground ballscrews are expensive all right. If you can snag some cheap off of Ebay, you can assume that some else has "eaten" most of the original cost.
Try Reid Tool if you can stand lower precision rolled thread ballscrews, or even plain threaded screws.
how do i choose the right lead screws? dansal DIY-CNC Router Table Machines 32 04-06-2009 03:48 AM
Question obout acme threaded rod (lead screws) Hack Mechanical Calculations/Engineering Design 1 04-02-2005 12:12 PM
Duel Lead Screws bb99 Mechanical Calculations/Engineering Design 6 03-18-2005 02:51 PM
Twin lead Screws Joe_CNC Employment Opportunity 3 04-09-2004 12:18 PM
Lead Screws mdframe DIY-CNC Router Table Machines 14 03-21-2004 08:20 PM
