Old 01-23-2004, 09:05 AM
ljoe1969 is on a distinguished road
I Need Info On 5 Phase Stepper Motors.
CAN SOMEONE TELL ME THE PROS AND CONS OF 5 PHASE STEPPER MOTORS VERSUS BIPOLAR AND UNIPOLAR?
Old 01-25-2004, 06:34 AM
ballendo is on a distinguished road
Hello,
Pros: Claimed to be smoother in operation. These are really aimed at the high end of the stepper market.
Cons: High cost of motors and drives. Drives scarce in the used market, motors sometimes found cheap (cuz no one can afford the drives to use 'em!)
Only a few sources for motors and drives.
Since most DIY-CNC folks don't use 'em, you're on your own if you have problems
Generally only available in size 23 (used)
Higher fullstep count means that speeds may be an issue depending on your controllers pulse rate output.
Hope this helps,
Ballendo
Does anyone know of a controller board for synchronized stepper motors Yellowbeard Stepper Motors and Drives 2 04-03-2005 11:06 PM
Looking for controller board for synchronized stepper motors Yellowbeard General Electronics Discussion 0 04-02-2005 08:50 AM
Whats the difference between xPhase Stepper Motors? roberto Stepper Motors and Drives 4 02-15-2005 02:10 PM
need info on sigma stepper motors gv71 Stepper Motors and Drives 1 06-26-2004 01:25 AM
2 phase vs 4 phase stepper motors Don C General Electronics Discussion 1 05-26-2004 01:40 PM
