Old 01-22-2004, 08:42 PM
drakesis is on a distinguished road
Controllers?
Hi All,
I was wondering if anyone has used these controllers?
http://www.lowcostcncretrofits.com/
looking for feedback. Thanks
William Desrochers - Excalibur Creations & Recognition
Raster Bitmap to Vector Conversion Service
Old 01-22-2004, 09:50 PM
Scott_bob's Avatar
Mfg Engineer
Scott_bob is on a distinguished road
Ever heard the phase:
You get what you pay for?
Not always, but if something sounds to good to be true, it usually is.
The best things in life, are not dirt cheap!
Sincerely,
Scott_bob
Scott_bob
Old 01-22-2004, 10:06 PM
anoel's Avatar
anoel is on a distinguished road
Dude... For $699 that's a really crappy deal....
That controller has no inputs/outputs for Home and Limits. and those steppers.... Puh-leese... 7.5 degree.... ugh.... You'd have to gear them down to get any resolution. There goes speed out the window....
A Xylotex controller with the steppers they sell and a 24v power supply will run you less money and out perform that setup easy...
Hell for that matter you could go with 3 Gecko 201 drives power supply and steppers and still come out cheaper...
No "Low Cost CNC Retrofit" there...
(Note this is my own opinion and is not biased toward any particular manufacturer. Tax, Tags and Title not included. Action Figures sold separately. And any other disclaimers that you can think of...)
Nathan
Old 01-22-2004, 11:01 PM
pack rat is on a distinguished road
They even have it with gecko's 201 for $1299 which makes it even crappier deal IMHO.
Old 01-23-2004, 02:59 PM
yukonho is on a distinguished road
I just got my router up an running. I am using Xylotex controller with the steppers they had on sale. I got a 24V power supply off ebay for 20 buck. I downloaded MAch2 (fantastic!) My total price was $250 including shipping. The setup I have works awesome. Honestly, plenty of speed on the rapids, even using 1/4-20 threaded rod for my leadscrews and 24V, 36"/min jograte. Get the xylotex stuff. First rate, works great, inexpensive, true chopper drive. You will be happy and richer!
co
Old 01-23-2004, 03:25 PM
buscht's Avatar
buscht is on a distinguished road
How about this?
http://www.denvercnc.com/controller.htm
Old 01-25-2004, 08:22 PM
ger21's Avatar
The DenverCNC box is a Xylotex inside.
Old 02-09-2004, 10:10 AM
mysterious's Avatar
mysterious is on a distinguished road
ger21,
Is it a fact that Denvercnc uses the same xylotex boards from their website? If they are I think it is an ok deal for a packaged product.
Old 02-09-2004, 11:22 AM
ger21's Avatar
That's what I've read, but you may want to check into it to verify it. Try emailing Jeff at Xylotex, I'm sure he'll let you know.
Old 02-10-2004, 05:03 AM
ynneb's Avatar
Moderator
ynneb is on a distinguished road
I am so glad to have found this forum. I was about to buy the talked about lowcost setup.
Now I am very confused. Do I use servos or steppers. Do I use Gecko or Xylotex.
I am looking to build a 4' x 8' router table to cut 10mm customwood.
Arrrrrrrrh, the more imformation I get the harder it is to descide.
  #11   Ban this user!
Old 02-10-2004, 10:37 AM
ninewgt is on a distinguished road
For 1200..... Id look at getting Gecko 201's, and Ability Systems Indexer and G-Code controller - Very smooth running, accurate, easy to setup and proven in the field. I have it on my machine and love it.........
Go for steppers - Great accuracy, easy setup, less cost.....
Persistance and patience are the key to CNC
  #12   Ban this user!
Old 02-10-2004, 11:11 PM
turmite is on a distinguished road
I have the Mach2 controller which is $159 ?? U.S. and that is a bargin. Support is second to none. I also use the Gecko 201s and steppers. I will be build my own design machine sometime this spring or summer ( I hope ). I had intended to use servo's with the Rutex drivers due to their higher voltage but after seeing the results of the Mach2/Gecko/stepper combo I may well go that route again. Whatever you decide to do.........please take my advice and don't get in a hurry. BTW the Mach2 has something in excess of 500 members on a Yahoo board that are as helpful as here.
Paul I didn't mean that, really I didn't I promise!!
Oh yes something I almost forgot. Gecko is coming out with a new controller (you'll still need drivers) that will output in the ___________ of pulses per sec. How about a stepper turning ____ rpm. I won't post the actual numbers till I verify them but they are unbelievable!
Mike
No greater love can a man have than this, that he give his life for a friend.
Slo-Syn Motor Controllers rimcanyon General Electronics Discussion 11 12-19-2008 07:35 PM
Misc surplus controllers, need help Hobbiest General Electronics Discussion 7 03-19-2005 12:54 AM
Other controllers that output step/direction? cn00728 General Electronics Discussion 3 02-02-2005 01:30 PM
Controllers from big name companies (compumotors) bgolash DIY-CNC Router Table Machines 1 09-06-2004 12:39 PM
stepper controllers - - -help please camfambmw5 DIY-CNC Router Table Machines 5 09-20-2003 12:59 AM
